Grant wrote:Hi all,
Has anyone converted their Mazzer (a Major in my case) to the doserless version using the kits from Espresso Parts, and if so, are you happy/disappointed with the results. From the "look" of the kit here, the only downside I can see is that it looks like it may make it difficult (impossible?) to sweep the grounds from the chute after grinding. My intention is to use it shot-by-shot for espresso...not bulk grinding.
I simply LOVE the way it grinds in comparison to my Macap M4 (stepped)...far better extractions even when the stepped grinder is dead on...but the size/doser height etc. make it very awkward as it towers over my machine now. Not to mention speed!
Considering a short hopper conversion and doserless conversion. Any thoughts/suggestions appreciated.
Grant
p.s. Anyone know if the Macap stepless grinder mechanism can be obtained/mounted on a stepped M4?
Grant wrote:Hi all,
Grant
espressoperson wrote:Yes to the doserless conversion but there's a better way here. Easy to sweep out between fillings, easy to fill portafilter basket, no static.
Why use a hopper at all? Put in just enough fresh beans as needed; cover with tamper or inverted shot glass, or anything that covers the opening and prevents beans from hopping out.
IMAWriter wrote:Can I assume the process is reversible?
Spresso_Bean wrote:I saw that EPNW sells a plate similar to what you did with the aluminum:
http://www.espressoparts.com/product/MAZ_206
Would this be something that could cover the opening from the doser if removed, or at least the part below where a homemade spout would go? It doesn't appear to have a chute opening, but I thought it might possibly be another option since they sell it in Mini and SJ versions.
