www.eccocaffe.com: custom coffee roasted in Northern Italian style
Mazzer doser fins modification - 2.0b
Link to "Mazzer doser fins modification - 2.0b"by RegulatorJohnson on Mon Jan 15, 2007 4:43 pm
I have made some doser fins.
They are similar to the standard tape mod only now with super whisker scraper tip.
I also have made up some fins for the top bars on the doser star thing. These clean the flat area above where the coffee falls into the PF, they work ok but have some issues to resolve.
i have 5 sets available (6 bottom fins, 2 top fins) anyone want to try these out?
jon
jon stovall
bevalo.com
thebeaningoflife.com
RegulatorJohnson
Mazzer doser fins
Link to "Mazzer doser fins modification - 2.0b"by pauljolly65 on Mon Jan 15, 2007 8:04 pm
Johnson, that looks like a great mod for the Mazzer. I've got a used Super Jolly which, while it grinds brilliantly, has a hard time getting all the grounds out of the doser. I've thought about removing the doser entirely & attaching a spout instead. Your fins look good, however. They look like some kind of thin aluminum flashing--is that correct? And how are they attached?
Cheers,
Paul
pauljolly65
www.dailygrind.com: artisian roasted coffee and espresso equipment
Link to "Mazzer doser fins modification - 2.0b"by RegulatorJohnson on Mon Jan 15, 2007 8:21 pm
sorry i forgot to specify the material.
it is "metallic" vinyl sticker substrate. it comes in about 40 different colors. want some pink ones? :D
soft. pliable. bendy.
NOT metal.
it is pressure sensitive adhesive, like a sticker it can be pulled off.
3 layers of the sticker material (folded).
seems to sweep cleaner. the whisker thing sweeps underneath the inner edge of the star.
jon
jon stovall
bevalo.com
RegulatorJohnson
Link to "Mazzer doser fins modification - 2.0b"by DigMe on Tue Jan 16, 2007 10:34 am
Is there a difference between what you've done here and the electrical tape mod?
bc
DigMe
Link to "Mazzer doser fins modification - 2.0b"by RegulatorJohnson on Tue Jan 16, 2007 11:04 am
DigMe wrote:Is there a difference between what you've done here and the electrical tape mod?
no not really.
the tape mod in its basic form wasnt workin for me. i work at home and sometimes get bored of clicking the mouse. i decided to pull out the exacto knife and the vinyl.
i had a few different mutations of the tape mod. different tapes, materials, thicknesses, shapes, adding various things inside, etc.
i rounded corners (will change from the pic) added the whisker that goes under the edge where the tape cant. these ones are also longer and fully wrap under the entire fin piece and the extra edge of the fin scrapes the corner a bit better for me. more pressure maybe?
the top ones are a bit different, i havent seen a top fin yet. but these ones are installed by taking it apart. the top fins stick on the under side of the top star flush with the center hole. these top fins also "push" like a bulldozer instead of dragging like the bottom fins. because they are on the inside underneath the star they can scrape out that coffee that gets packed in there under where you cant brush easily.
these are already folded and ready to stick in there after you clean the surface.
jon
jon stovall
bevalo.com
RegulatorJohnson
Link to "Mazzer doser fins modification - 2.0b"by pauljolly65 on Tue Jan 16, 2007 2:15 pm
RegulatorJohnson wrote:i have 5 sets available (6 bottom fins, 2 top fins) anyone want to try these out?
Yes! Can you email me off-list and let me know how to get ahold of them?
Thanks,
Paul
pauljolly65@yahoo.com
pauljolly65
Link to "Mazzer doser fins modification - 2.0b"by RegulatorJohnson on Tue Jan 16, 2007 2:23 pm
anyone else can just PM their address to me.
jon
jon stovall
bevalo.com
RegulatorJohnson
Link to "Mazzer doser fins modification - 2.0b"by Psyd on Tue Jan 16, 2007 6:34 pm
RegulatorJohnson wrote: it comes in about 40 different colors. want some pink ones? :D
Ehm, it'd go with my mod!
These are just large plastic easter egg halves (you know, the ones they hid with chocolates and jellybeans in?) that I've fitted over the top star.
When you have the thing out for cleaning, just heat it up gently with a gas stove or a propane torch. Careful not to get it too hot, as it isn't really designed to take a lot of heat. Any discoloration of the metal and you have gone way too far. Practice with a coupla throwaway egg parts and some scrap metal pieces first. Find a surface that you can set hot metal on that won't sink away too much heat, and then heat the star, center the egg-half, and gently press it into place. Take special care not to press the egg past flush with the star's bottom, or it will bind on the dosing sector (the lil shelf that sits above the doser exit chute and splits the upper and lower star sections).
Run it under cool water when you have it where you want it, but be careful that the star isn't still hot enough to deform it when you pick it up, and it'll become set. Gently pull the egg away from the star, and clean the edges with a razor knife. A small dab (really, small) of silicone, Elmer's, or other cement in each of the new indentations that you've made will keep it in place through all the brushings, but allow you to take it up when you wish to disassemble the grinder for cleaning.
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "Mazzer doser fins modification - 2.0b"by pauljolly65 on Mon Jan 22, 2007 12:31 pm
I got a set of these from RJohnson and installed them in my old Super Jolly. Installation took about 30 minutes (would go much more quickly with experience, but this was the first time I'd dug into the doser). Not only was it an easy mod, but I'd say it's eliminated 90% of the stray grounds which had been collecting in the doser. No more brushing it out after each day! Thanks, Regulator!
pauljolly65
Link to "Mazzer doser fins modification - 2.0b"by mobleyfan on Mon Jan 22, 2007 7:58 pm
I gave this a shot as well. I think I may have need to apply them lower than they appear in the photos as I'm not getting a completely clean sweep. However there is a clear improvement and fewer grounds are remaining. Thanks!
-Sam
mobleyfan
Link to "Mazzer doser fins modification - 2.0b"by cannonfodder on Thu Jan 25, 2007 7:45 pm
I did the tape mod on my mini a month or so ago. I had the same initial thought, it does not work that well. Then I realized I had the doser all the way up. Try tightening the center nut in the doser which adjusts the height of the vanes. Crank it all the way down and see what happens. You should have a half inch of screw above the big center adjusting nut.
cannonfodder
Link to "Mazzer doser fins modification - 2.0b"by Fullsack on Thu Jan 25, 2007 10:09 pm
For those of us less inclined to do mods, I'll mention my ritual. After each session, I scrape out the pathway between the grinder and the doser, run the grinder for a second and clear the path again, (my finger guard was removed early on). Then I rotate the doser lever with a 1" paint brush inserted in the doser. I brush the doser and run the paint brush around in the doser a second time.
Cleaning old grinds from the burrs, grinder pathway and doser makes sense. When you see how many old coffee grinds are removed, you realize that a good percent of what ends up in your filter basket could be old grinds.
Doug Jamieson
Full Sack Jack Coffee Roasters
LMWDP #017
Fullsack
Link to "Mazzer doser fins modification - 2.0b"by affas on Wed Aug 01, 2007 8:09 am
Here is a couple of pictures of my SJ with sweeper mod and the spinner mod to avoid old coffee staying in the doserImage
Thanks,
Alf
affas
Link to "Mazzer doser fins modification - 2.0b"by Randy G. on Wed Aug 01, 2007 10:11 am
I originally used the electrical tape mod on Rocky, but later, when the tape became a bit old and gummy on the vanes I switched to using the fuzzy side of heavy duty velcro. Although the fuzzy will retain a bit of coffee, the mod works well, particularly in grinders with dosers made with lower tolerances because the velcro works like broom bristles, conforming to uneven surfaces well, and it seals against the outside walls and into the corners quite well.
Espresso! My Espresso!
Randy G.
Link to "Mazzer doser fins modification - 2.0b"by Psyd on Wed Aug 01, 2007 2:36 pm
affas wrote:Here is a couple of pictures of my SJ with sweeper mod and the spinner mod to avoid old coffee staying in the doser
So, while I'm a huge fan of the pink easter eggs, I'm drawn to the 'spinner' mod. What is that thing, where did you get it, how hard to modify, etc?
Espresso Sniper
One Shot, One Kill
LMWDP #175
Psyd
Link to "Mazzer doser fins modification - 2.0b"by affas on Wed Aug 01, 2007 2:42 pm
The spinner I used is intended for radio controlled airplanes and they are made in all kind of materials, plastic, metal, carbon and fiberglass. And I am sure you will find a pink one..............
Most of them have already a hole in front center.
Just remember to buy a bigger spinner since you need to cut it off due to the cutouts for the propeller.
I will post a picture of my spinner being cut in two pieces.
Some variety;
http://www.horizonhobby.com/Search/Default.aspx?SearchTerm=spinner&CatId=&Page=3
Thanks,
Alf
affas
Return to Espresso Grinders
