I've had the Macap for a few weeks and I love it. In case anyone was also wondering about the questions I asked in the first post I thought I'd give my own answer now that I have had it for a while.
1) Chris' coffee was right that the on off switch was a good choice. The timer might be an equally good choice, but I certainly don't miss it. A few people online didn't like the plastic cover, but it is not an issue on my machine at all.
2) I think the chrome looks great (although as I mentioned before, it is bigger than I thought). There is nothing cheap looking about this machine.
3) A small protafilter works fine under it. My counter isn't spotless when I'm done, but there isn't much wasted coffee on it (and what does spill is probably my fault and is easy to clean up).
I also love the doser even though before reading these forums I'd thought I wanted a doserless machine.
I'd been worried about too much buildup remaining in the doser, but when I asked around I was told that the doser would be swept quite clean, but that the chute would have some buildup and this would be true of the chutes on both Mazzers and Macaps and they were quite right (at least about the chute vs doser on this machine). There is almost no coffee left in the doser, but the chute does need to be cleaned out regularly.
In summary, I am thrilled with this machine (although I expect the same would have been true about the Mazzer mini if I'd bought it).
JohnB. wrote:Check out this thread on CG:
http://www.coffeegeek.com/forums/...so/grinders/349880 (once the CG server comes back on line) This mod makes it MUCH easier to remove the upper burr/hopper assy for cleaning. It will also allow you to make quick grind changes if using the stepless Macap for different types of brew grinding.
JohnB, CG is working fine for me, but I still can't get this thread to come up. I'd be interested in reading it if you can point me to it in another way.
