Hi all
It looks like I'm going to buy a new PID regulator which normally costs around 150$, but I might pay only 40$:) Will see how the auction goes.
Now the next problem is fitting the damn thermocouple in the group. Normally I would buy Eric's adapter, but because I'm on a tight budget I would love to cut costs a bit. I found similar TC adapters on Swagelok (Erics original idea) and Omega (OMEGAlok fittings) which both cost around 10GBP (but shipping for Swagelok costs a whooping 8 GBP, the same as the fitting alone:|). Now as Eric already noticed (and most of you on HB) there's a problem with screwing the fitting in the group as the hole is in a hollow. I came up with and idea to custom make a thread converter which would look like this:
The only problem is I can't find anyone who would make one for me. I was hoping to get it done in Poland (I'm originally from Poland) but most lathe operators won't do small quantities (I only need one or two).
I can always buy a second group screw, drill it and use some epoxy to stick the TC in place. I wouldn't want to do it as it means the screw is stuck to the TC for good and because the TC costs 15GBP it would be cool to use it in the future without something stuck to it.
I know that someone on HB did drill a M6 screw and it worked. Was it you cannonfodder?
Cheers,
dsc.
