grong wrote:timo888,
Sorry I misread your post about unground beans!
Absolute volume calculation suggestion: I asked my wife, who is a math person, if she could calculate the volume of the single basket easily. She suggested I fill it with water, and measure the water in a calibrated shot glass. Adhesive tape across the bottom of the basket seals the holes from leaking. This works great, and is probably more absolute than unground beans.
Basket shape: We could label your drawing of a basket with letters to designate the parts, then in a simple chart with the letters in one column, fill in the appropriate measurement. With this, we could reconstruct any basket shape, I think.
Best,
grong
Hello Grong,
There was an H-B thread a while back " Archimedes Challenge:"
http://www.home-barista.com/forums/post17432.html#17432A few different methods of computing basket volume were suggested. And here would be a good place to use one that is compatible with all baskets. If it were salt or sugar, the brand and grind must be specified!
Using unground beans as a volume dose may require a different amount for every bean type and roast(size,) basket diameter, depth and bottom radius. With the roasted beans I buy, that works for me. I can make up the variables through measuring container, grind and tamp.
Timo888 wrote:And I'd like to see the chart include basket shape variants and their capacities while we're at it.
Regards
TImo
Hello Timo,
Remember 1cc =1ml. That is a difference of maybe .2mm or .008 on the measured inside radius of a deep straight sided 51mm basket!
How do we measure the height and degree of the angles and define the center of radius for the various radii of the various basket types????Their diameters at what points? Inside or outside? Whether the basket rolls over the top of the PF or is contained in and only the top edge contacts the group gasket? What about quantity, size, shape and pattern of perforations. Thickness of metal at various points of the basket? Let alone the simpler measurements of diameter, height of the basket itself or the level it is filled to (headspace.) What tools does
everyone have
at home to define the basket?
After reading many H-B threads, I can think of at least ten variables for basket definition which could make a difference in performance.
I would need to go into my toolboxes and get at least four relatively expensive tools and tool sets ( approximate total cost on the cheap=$350+) to do a fairly decent job of describing the
outside geometry of any given basket. This could be a forever project.! I've worked at design drafting, tooling design and metrological fixture design for incoming parts inspection and such questions will make a huge difference in whether a part always fits or whether a supplier receives payment.
I am not being facetious. All these H-B thread efforts to get inter-machine variables down to absolute science waste everyone's energy and time. That time could be spent relaxed, enjoying a good "Cuppa"
Some useful opinions and future individual direction can come from looking at relative basket shape, size + tamp. BUT that is only a beginning of the experience of making good coffee.
It is like asking a centipede which leg moves when. Total confusion instead of a natural movement!
Nit-picking wastes the time and energy of others!
Each person will make decisions according to their taste and training. Another person and I get a very different resultant volume in cup using the same lever machine. I can grind the same roast with the my Rocky at the same setting, the same weight measured by triple beam balance into the same tared dry basket and use the exact same basket on two different machines side by side and get a totally different result in the cup and mouth.
Best regards to all!
richard
