LeoZ wrote:Has anyone measured actual brew pressures (and temps) of their lever machines?
I tried measuring the brew temp once but it wasnt accurate, at least I dont think so - temps were around 187F through the shot with a thermocouple snaked into the basket.
I am more curious in brew pressures though. HX machines max (adjusted obviously) at around 8.5-9.5 bar, and brew temps of 195 -205F.
Any correlation?
It would be nice if there were some sort of OPV setup on levers, this way you dont get stuck waiting 20mins if you grind too fine
Paul Pratt sent me some data on one of his restored spring lever machines. As I recall the max pressure was 8 bar, falling to 6 at the end. I measured the PV Lusso brew pressure as part of the Lever machines smackdown. I think it produced fairly low pressures - not anywhere near as high as what is customarily used.
I built a one-off thermofilter for measuring brew temps on the Lusso as part of the smackdown. I made preliminary measurements with it, then sent it off to Dan Kehn, who is sposed to do more exhaustive work with it. For boiler pressure of 1.1 bar, Lusso Brew temps are in the ranges that we accept as pretty decent - around 200ish, but decline sharply throughout the extraction (6 degrees F or so). The Lusso has a pretty small piston chamber and double espressos require two pulls. The temperature of the second pull rises quite a bit compared to the first, but exhibits the same declining profile. I'll let Dan fill in the details when he gets time. I don't have my records here and as i mentioned, the measurements i did weren't exhaustive by any means.
-Greg
