Ponte Vecchio Lusso: The little machine that could.
I have only been using the single group Lusso for 3 days but have quickly come up to speed on the little box. I would normally work with a machine for a week before I do any writing about the system. However, I have had hands on tutorial of the machine along with the previous user's reviews. Armed with that knowledge, I brought the Lusso home and hooked it up on my espresso bar.
I broke out the owners manual, yes some of us still look before we work, and leafed through it. I was not expecting much, most espresso machines have rudimentary owner manuals and the Ponte Vecchio is no exception. The basics of the machine are covered, what is where, and basic operation but not much else.
I filled up the boiler and powered up the machine. As I stated earlier, the Lusso has no vacuum breaker so false pressure must be vented after the initial heat-up. The owners manual listed the heat up time as 10 minutes. I was skeptical. The Lusso single group has a 3 liter boiler and a 1200 watt heater. That is a lot of water, and steel/brass to heat in a very short time. The machine will complete its initial heat up in 10 minutes, false pressure still needs to be purged. Open up the steam wand and purge the boiler for 10 seconds then let the machine come to temperature again. That takes another 3 minutes.
Unlike the other machines of the lever machine Smackdown, the Lusso uses a thermosiphon similar to those used by E61 groups albeit on a smaller scale. While the boiler comes to temperature in under 15 minutes, I find that the group and rest of the machines steel body needs at least a half hour of heat up time. You can speed the process by purging some water out of the group but keep in mind you are depleting your brew water. Once empty, the machine will need time to cool down before you open the boiler to add more water. Then you have to go through the entire heating process again.
While I am on the subject of heat, let me mention the little machine's unique ability to not overheat. Because the grouphead is not attached to the boiler it does not overheat like the other Smackdown participants. You can even leave the machine on for extended periods. I ran the little box for two days without powering it down. I pulled shots until the boiler hit the low limit and never had any heat issues, other than it running cool unless I do a warming flush before the shot.
I loaded the Cimbali Max up with some
La Bella Vita espresso blend from PT's Coffee, made a guess at my grind based on the Elektra Microcasa Leva and pulled my first shot. I was surprised; the extraction was on the money. The shot was all crema and flowed like honey. The resulting diminutive shot was brighter and more acidic than the shots from the Gaggia Factory with a little less body but not quite as bright as the Elektra. The big shocker was the diminutive amount of espresso a single lever pull produces. I gathered a scant half ounce or so of espresso. While tasty, it was hardly enough for the amount of coffee I used. But this was my first pull on this machine and there is much more testing ahead.
The Lusso uses a very small portafilter -- the smallest I have ever used. The baskets make up for their small diameter by being deep. I can fill the basket to a small mound and do a no pressure sweep to level off the basket. The resulting dose is in the 11.5 gram range, give or take a couple of tenths. I have been using 11 to 11.5 grams in my shots so far with good results. I will point out one annoying problem. The basket is so small in diameter that I end up with a teaspoon-ish worth of grounds in the drop tray. The basket is so narrow that some of the grinds will miss while thwacking the doser handle. I may start dosing into a ramekin and then transferring it to the basket but it is really more work than I want to go through.
The basket is not the only small part on the Lusso. The piston is equally small. The piston stroke appears to very close to that of the Elektra Microcasa Leva. The reduced diameter of the piston means it pushes less water with each stroke. Pulling a single stroke shot with the Lusso using a double basket produces a shot that would barely overflow a thimble. A multi-pull is required to get more than a sip. If you use the single basket, a single pull would be more acceptable due to the reduced dose.
The single pull, multi pull discussion is described in detail in the
Lever multiple pull techniques thread. I will not be debating the pros or cons of this technique but I will elaborate on how I pull a shot on the Lusso.
I start by pulling an ounce of water through the group and portafilter into my demitasse cup to both preheat the group and the cup. Then I grind my fresh beans and dose the double basket to just below the top rim of the basket for an 11 gram dose. I give that a quick leveling sweep with the back of my little finger followed by three thumps on my tamping stand to further level and settle the coffee bead.
Then a nice light tamp to settle the puck.
I then empty the water out of my cup, lower the lever until a little water flows then back off until it just stops. At that point the lever is around half cocked. Then I lock in my portafilter, lower the lever to the bottom of the stroke and hold. I keep the lever depressed for 7 seconds. While the lever is depressed I place my cup under the spouts. Once I release the lever I allow it to travel until the first few drops fall into my cup. I then re-cock the lever, hold it for another 3 seconds and release. I allow the lever to travel through a full stroke to complete the shot. That dispenses just over one ounce of espresso.
Just for clarification, the Lusso has a double spouted portafilter, espresso was just flowing from one spout when I snapped the photos, hence the appearance of a single stream.
So far, this is working well for me but as I mentioned earlier, my time with the Lusso has been short so my opinion/technique may change over time.
I am finding the shots on the Lusso to be quite good. The shots are brighter than the LaPavoni with more clarity in flavor but with less body yet slightly less brightness than the Elektra Microcasa Leva but with a touch more body. The little Ponte Vecchio Lusso appears to fill a niche between the two cup styles of my other machines. I still reserve the right to change my opinion as my time with "the little machine that could" progresses.
