by cannonfodder on Mon Aug 14, 2006 7:40 pm
I have pondered this question for some time. My conclusion to the leave it on or turn it off question, there is no answer, whatever works for you is the correct response.
I have insulated the boilers on both of my machines which appears to substantially reduce the boiler cycling and hence energy consumption. My Isomac, which resides at work, I turn on in the morning when I get to my office and turn off when I shut down my computer. A 1.5 liter e61 heats quick so time is not that big of an issue, provided you plan ahead. On hot days, I will cycle it on, pull a shot an hour later and turn it off until next time.
The Faema is a different story. A commercial machine takes about two hours to come to temperature. During the summer, I still power it down when I leave for work. It just pumps too much heat into the house. I have the wife turn it on about an hour before I leave so it is hot and ready when I get home, then off again for the night. During late fall winter and early spring, I will leave it on since heat is not a problem.
Group gaskets are cheap and easy to replace. You need to pop that dispersion screen off now and then to clean it anyway. The internal components are designed to take the heat. There may be an O ring that hardens over time and needs replaced but consider you are talking about a $.19 part and only a few moments to replace. Once again, a perfect time to clean the inner workings of that steam valve or water tap, nothing keeps a machine in top working form better than some occasional preventative maintenance.
