by SNielsen on Sun Dec 16, 2007 3:35 pm
My Giotto has sprung a leak at the grouphead -- specifically around where the lever shaft enters the head, right beside the cam. It only leaks when pulling a shot, and there is some back pressure in the system. When flushing water through (no resistance) there is no leak.
The odd thing about it is that it didn't start leaking until I pulled the mushroom out of the head to inspect it for scale (it was clean), and then reinstalled it. What went wrong? I put it back in correctly (I think). Is this just an unfortunate coincidence? Or did I screw something up when I put the mushroom back in?
FYI, I tightened the nut beside the cam (it was not loose, but I snugged it up anyway), but it made no difference.
Looks like I may have to take the shaft out and replace the gaskets in there, but if anyone has any experience with this, any help would be appreciated.
Best regards,
Svend
