www.klatchroasting.com: USBC champion, voted 2007 WBC 'best espresso'
Le'Lit PL53 Stepless Doserless Espresso Grinder
Read about current and future offerings from the site sponsors.
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by 1st-line on Tue Dec 11, 2007 10:53 pm
Killer price for a Killer grinder! The LeLit PL53 stepless espresso grinder.
I have worked on this grinder with the manufacturer for the last 6 months - making refinements, adjustments, etc. This grinder has gone through my torture chambers for the past 6 months across multiple espresso machines - only result was to not be displeased.
The LeLit PL53 grinder is in stock.
The only all stainless steel, polished body, doserless, conical burr espresso grinder with stepless adjustment for under $250.00. Can we say more? This grinder was designed for grinding for espresso. Although the PL53 can be used for other coffee brewing methods, the turning of the knob on the stepless adjustment can be cumbersome to rotate many times for different brew methods. This is why we recommend the grinder be utilized for one brew method only.
More details on our web site: www.1st-line.com
1st-line
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by jamhat on Fri Dec 21, 2007 10:02 pm
The new grinder looks really sharp. I'm in the market right now for a new grinder to match up with my Gaggia Factory (la Pavoni rebadge). The Factory is pretty picky.
How fine does the new Le'Lit grind? Would you say it will grind as fine as Turkish?
LMWDP #145
jamhat
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by 1st-line on Fri Dec 21, 2007 10:24 pm
jamhat wrote:The new grinder looks really sharp. I'm in the market right now for a new grinder to match up with my Gaggia Factory (la Pavoni rebadge). The Factory is pretty picky.
I have actually choked a few espresso machines with the very fine grind settings on the LeLit . Although it came out like powder, I would say it achieved Turkish grind.
Jim Piccinich
1st-line Equipment, LLC
1st-line
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by Branden on Sun Dec 23, 2007 8:29 pm
A few questions:
    1. Is it possible to operate without the hopper?
    2. What size are the burrs?
    3. Beyond espresso, would this work as a portable grinder for cupping samples?
Also, I am confused about the actual name of this grinder. Near the 'Buy Now' button on the website it is called "Le'Lit PL53110" whereas above the description it is called "Le'Lit PL041." Is there a difference?
Branden
Branden
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by ccfore on Thu Dec 27, 2007 5:57 pm
Are there additional pictures of this that might show the front profile a little better? The PF rest, or at least the folded metal part on the right, is hard to see and the left side looks to be totally different. Thanks.
Todd / LMWDP #109
ccfore
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by 1st-line on Fri Dec 28, 2007 6:00 pm
Branden wrote:A few questions:
Anything is possible. We do not suggest operating any grinder without a hopper.
Burrs are 38mm OD on the larger burr.
The grinder is really intended for espresso. Actually, all stepless grinders are really made for espresso. The stepless adjustment really makes it impractical for other brewing methods.
There were some typos on the description as we were rushing to put this page up. Sorry about this. page has been corrected.
Jim Piccinich
1st-line
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by 1st-line on Fri Dec 28, 2007 6:02 pm
ccfore wrote:Are there additional pictures of this that might show the front profile a little better? The PF rest, or at least the folded metal part on the right, is hard to see and the left side looks to be totally different. Thanks.
More pictures will be posted once our programmer returns from vacation. Unfortunately, there is too much reflection in the catch tray. The two folded metal parts do accommodate up to 58mm portafilters.
Jim Piccinich
1st-line
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by HB on Mon Dec 31, 2007 3:28 am
Last month Jim mentioned the Le'Lit PL53 doserless espresso grinder would be arriving around Christmas time. No formal review is planned, but I offered to provide some feedback since there's not a lot of information on it.
First of all, it's a nice looking grinder and has decent heft. The doser spout removes easily to reveal the exit chute, which is short and sloped. Very little grounds are retained and they are nearly clump free. I've pulled a few espressos with the LeLit grinder and dialing in was a breeze. I'll post more comments when I've gotten a few dozen espressos behind me. In the meantime, below is a quick video of one of the first extractions:
[gvideo]http://video.google.com/videoplay?docid=-3074954112856045778[/gvideo]
(Astute observers will note the new espresso machine in the video above; it's a "loaner" Elektra Microcasa Semiautomatica from Jim Schulman. I'm starting to grow rather fond of it... Jim, we need to talk. :wink:)
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by HB on Mon Dec 31, 2007 6:07 pm
I pulled a half pound worth of espressos using the Mazzer Mini Electronic Friday and Saturday; yesterday and today I finished the other half using the Le'Lit PL53. In terms of usability, the Mini E is the best doserless I've used; its timer doses are consistent and the large funnel routes all the grounds to a single spot. The coffee grounds from the Mini E are nearly clump free, but the PL53 is even better:
The grounds are noticeably "fluffier" than the Mini E. For the photo above, I held the portafilter straight out, pressing it against the grinder's black momentary-on button. As you can see, unlike the Mini E that drops the grounds dead center, the PL53 throws to the left. This can be corrected by carefully redistributing the grounds after the grinding is finished, or by rotating the portafilter handle while the grinder runs. Rotating the portafilter from the 9 o'clock to 6 o'clock to 3 o'clock position is standard operating procedure for me when using doser grinders, however 9-to-3 o'clock rotation is inhibited by the PL53's portafilter rest "wings". That is, because you must press against the on button with the portafilter to keep the grinder motor engaged, the practical rotation is more like 7-to-5 o'clock (*). In the end, I opted instead to stop mid-grind, jiggle the portafilter gently to topple the left-weighted pile of grounds to the right, then finished with a Stockfleths Move. The result was very even pours again and again.
Although the tastings were not side-by-side, some general impressions did emerge; I caution you to treat these as preliminary. As noted earlier, dialing in the PL53 was easy and the extractions exhibited good striping throughout the pour. Counter Culture Coffee's Espresso Aficionado pulls rich and creamy; the crema from the Le'Lit PL53 was perceptibly lighter and greater in volume than the Mini E (sorry, I did not measure the brewing ratios). The flavor profile was also slightly different. Espressos from the PL53 were brighter and the nutty flavors transformed from black walnut to cashews. Very good espressos all around from both grinders. If these espressos were served at a barista competition, I would score them in the 3.5 to 4.0 range (explanation).
(*) To simplify distribution while dosing, the PL53 may be candidate for modification similar to the Rocky Doserless switch for continuous grind. Of course that would defeat the main switch's role as a safety mechanism and void the warranty.
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by HB on Tue Jan 01, 2008 11:41 pm
Today is the last day of my vacation and the end of my leisurely espresso mornings. Sigh. A couple tidbits from this morning's session:
  • Chute removal and cleaning - The exit chute is held on by a single plastic-capped screw (gray in the photo above). The inner bottom edge of the chute has a piece of rubber to seal against the grinder. The friction fit is tight enough that the chute stays put without the screw in place. Extreme neatniks can pop the chute off to brush out the prior day's grounds without difficulty.
  • Noise level - I owned a Solis Maestro and remember it whined loudly. Thankfully the PL53 is nothing like it. The PL53 is louder than the Mazzer Mini, but still within reason. Its sound and noise level reminds me of our food processor, if that helps.
I've moved all my equipment out of the kitchen into my home office. The outlets are a foot off the floor instead of the countertop backslash like the kitchen's, which brings up a minor point: The PL53's cord is approximately two feet long... not enough in my case. The Mazzer grinder's cord is almost twice as long. Oh well, it gives me the excuse to mount an outlet strip/surge protector.
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by 1st-line on Wed Jan 02, 2008 11:53 am
HB wrote:The outlets are a foot off the floor instead of the countertop backslash like the kitchen's, which brings up a minor point: The PL53's cord is approximately two feet long... not enough in my case. The Mazzer grinder's cord is almost twice as long. Oh well, it gives me the excuse to mount an outlet strip/surge protector.
Just a point about the cord.... my first prototype had a cord roughly two meters long - way too long to have so much cord on the countertop. To make this grinder very competitively priced, shortening the cord was one of several areas that would lower the price, but not the performance.
Jim Piccinich
1st-line
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by HB on Wed Jan 02, 2008 11:01 pm
Today is the first day back from vacation and the espresso gods took mercy on me. Mark at Counter Culture Coffee fixed me up with Lem's competition winning Twin Cities Express. It took two adjustments for the PL53 to narrow in on a good pour, then four wonderful espressos over the course of the day. Be forewarned that this coffee has a long rest period of at least 5-6 days. I had tried it earlier in the week and it was much improved today -- full of blooming crema, intriguing flavors, and enjoyable taste transition as it fades.
The PL53's adjustment is rather fine. Switching from yesterday's blend required a good full revolution of the adjustment dial.
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by HB on Fri Jan 04, 2008 12:59 am
HB wrote:The PL53 is louder than the Mazzer Mini, but still within reason. Its sound and noise level reminds me of our food processor, if that helps.
For an offline request, below is a sound comparison of the two grinders side-by-side:
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by aindfan on Fri Jan 04, 2008 11:37 pm
The review posts above make it sound like this grinder would be a perfect high-quality entry level grinder that is (both for price and quality) better than the Rocky and in some ways comparable to the Mini-E. Am I reading this correctly, and is this $200 grinder really putting up a fight against an ~$800 grinder? (Note: In making this very generalized claim, I am going with the assumption that I could accurately dose without the Mini-E's timer and that I can WDT out the few clumping issues that would remain)
Is this truly a grinder that would be a great alternative to a Mazzer Mini in the sense that it is more dorm-room friendly (smaller, less expensive, equally adjustable) for espresso-only use (if I am dialing in and sticking to one blend at a time).
Thanks!
Dan Fainstein
LMWDP #203
aindfan
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by HB on Fri Jan 04, 2008 11:57 pm
aindfan wrote:The review posts above make it sound like this grinder would be a perfect high-quality entry level grinder that is (both for price and quality) better than the Rocky and in some ways comparable to the Mini-E.
For the record, this isn't a review, just casual "first impressions" posts. :D
I haven't done side-by-side blind tastings, but you're right, I'm impressed with the quality of the extractions. It does produce less clumping than the Mini E and a lot less than the doserless Rancilio Rocky, which is a candidate for WDT poster child. I've not disassembled it, but I don't believe it's anywhere near the same level of sturdiness of the Rocky. For example, Rocky's burr carrier is made from machined brass and it has a beefy motor. Judging from what's visible from the exit chute, the LeLit PL53's burr carrier is a hard black plastic resin of some sort. I don't know the replacement schedule for the PL53's burrs, but I would bet it's more frequent than Rocky's and much more frequent than the Mini E's.
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by cannonfodder on Sat Jan 05, 2008 1:07 am
But you could purchase a bushel of burrs for the price difference. It looks like a nice entry level on a budget doesn't have any space to spare grinder. I don't think I would replace a Super Jolly or Robur with it; we are talking about two very different classes of grinders.
What I am reading (I have no first hand experience with it but I trust Dan's first look), it is a price point performer, there are better options if you have cash and counter space. However in the bang for the buck scale it scores very high. I know I would probably opt for it over the Gaggia MDF I once had.
cannonfodder
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by aindfan on Sat Jan 05, 2008 9:54 am
I don't think I could have put it better.
One issue: I was unable to find burrs for sale on the 1st-line website and on EPNW. It seems like 1st-line may be one of the only places that sells Le-Lit. What does this mean for burr replacement when the time rolls around? Any ideas how much new burrs would cost?
Thanks
Dan Fainstein
LMWDP #203
aindfan
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by 1st-line on Sat Jan 05, 2008 3:02 pm
aindfan wrote:I don't think I could have put it better.
Thanks
Currently, we are the exclusive importer for Le'Lit espresso machines and grinders. It looks like we have a distributor on board in Canada, and there will be more to follow in the USA most likely in the near future.
Please note that the pricing is introductory.
Finally, the bean hopper, bean hopper cover, and the burr set have been set up online sans pictures at http://www.1st-line.NET.
Jim Piccinich
1st-line
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by aindfan on Sat Jan 05, 2008 9:24 pm
1st-line wrote:Finally, the bean hopper, bean hopper cover, and the burr set have been set up online sans pictures at http://www.1st-line.NET.
I stand corrected. A quick search of "Le'Lit" on the 1st-line site showed me the burrs, currently at $30 (it says regular price $40). Looks fairly reasonable, depending on replacement schedule (as long as the price difference between this and a Mazzer is much less than the total spent on new burrs for about 4-5 years.
Dan Fainstein
LMWDP #203
aindfan
Link to "Le'Lit PL53 Stepless Doserless Espresso Grinder"by aindfan on Mon Jan 07, 2008 12:38 am
Now here comes the $200, $450, or $530 question: get one of these to hold onto for a few years (figuring for 2-3 burr replacements) or get a Mazzer mini used or new? This would be much more conveniently sized for a dorm room, but with the mini I know that I'm investing in a grinder that I won't get upgraditis with for a long time. The mini, however, seems messier and clumpier than the Le'Lit (notes about grinds going far left come to mind).
Any advice?
Dan Fainstein
LMWDP #203
aindfan
Next
Return to Marketplace
