The tc range was 205-204.1-205.3. The Scace range (after the first 6 seconds) was 203.4-203.8. Needless to say, this does not look much like either Dan's or Eric's charts, and is why I noted earlier that I did not get the temperature variance of 5-10 degrees F that others had noted. Nor do I get much of a hump despite a long flush (50 seconds and about 10 ounces) and a 40-second pause.
I have not yet taken measurements on successive shots, and these might prove revealing.
edwa, I don't know if this helps, but I hope it gives some relavance to the routine that I outlined earlier. As others have noted, the actual numbers are not that important, but the routine has brought some stabiity (on the first shot, anyway). I am going to (try to) ditch the meters, etc. as soon as I can fine-tune my sensitivities and solidify my routine. I hope your 'good enough' is very enjoyable!
