La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine
Read about current and future offerings from the site sponsors.
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by chris on Sun Nov 11, 2007 9:24 am
NEW MINI Vivaldi II Model S1 Dual Boiler by La Spaziale
Would you love a double boiler espresso machine, but can't install the plumbing required by most rotary pumps? Well then look at what just arrived this past Friday:
Compact and powerful
Easily accessible pull-out water tank
Electronically controlled brew temperature
I have 8 pre-sold and never advertised it anywhere until now. They are also ETL and UL approved. Other features:
  • Same software as regular Vivaldi II 15 & 20 easy to switch from one to the other.
  • Software shuts pump off if runs too long so you can not burn it out.
  • Lever steam arm same as La Spaziale uses on their commercial machines.
  • 1.2 Liter Steam Boiler but same 1250 watt heater. It's a steaming power house.
  • Sensor shuts power when water is low, controlled by magnetic float.
  • Timer can be added same one as regular Vivaldi II.
  • Vibe pump
The selling price is $200.00 less than Regular Vivaldi II.
More details: http://www.chriscoffee.com/products/home/espresso/minivivaldi
Chris Nachtrieb
Pres. Chris' Coffee Service, Inc.
chris
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by poison on Mon Nov 12, 2007 2:20 am
O
M
G
poison
New Mini Vavaldi H2O resevoir capacity?
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by errickson on Mon Nov 12, 2007 1:31 pm
Looking fwd to receiving mine! Thanks again for addressing this request from the marketplace. Question: What is the size/capacity of the H2O resevoir? Didn't see it here or on the website? Thanks!
Doh! Please disregard. Quick Google revealed the following...Unless this has been modified for your specs:
"3 ltr Handfill tank with low water level indicator"
errickson
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by Trisha on Thu Nov 15, 2007 3:08 pm
What would be the recommended surge protector? Living atop a granite ridge amidst granite mountains -- we do get electrical storms when the conditions are right.
That's a lovely machine!
Trisha
LMWDP# 95
. . . and cello sonatas flow through the air. . .
Trisha
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by errickson on Thu Nov 15, 2007 3:26 pm
Hi Trisha,
I cut-and-pasted this info below from Chas Rimpo's website he created for the S1. I had just read it a few minutes prior to you posting your question. Hope it helps...
Here is the direct link: http://www.rimpo.org/s1v2/faqs.htm
...and here is the info:
Where can I find a 20A surge suppressor?
The computer controller board in the S1 Vivaldi II costs several hundred dollars if it needs to be replaced due to a circumstance not covered under warranty. If you live in a lightning or power surge prone area, a surge suppressor is a good idea. Thanks to the prevalence of computers and consumer electronics you can find inexpensive ones almost anywhere that will work with the 15 amp version of the S1 Vivaldi II. HOWEVER, if you have a 20 amp S1 Vivaldi II model, finding a 20A surge suppressor with the NEMA 5-20 outlets is a challenge. The best and least expensive I have found - and I purchased one - is the Triplite Isobar "Ultra Copy" which was apparently designed with copy machines in mind. It plugs directly into a 20A NEMA 5-20 duplex outlet.
Considering product cost plus shipping, the following link is the least expensive source I have found. It also has full specs on the device. http://www.c-source.com/csource/n...?part_no=ULTRACOPY
Trisha wrote:What would be the recommended surge protector? Living atop a granite ridge amidst granite mountains -- we do get electrical storms when the conditions are right.
Trisha
errickson
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by jesawdy on Thu Nov 15, 2007 4:26 pm
I noticed that Chris' original post linked to the plumbed Vivaldi S1, and not the pourover 'Mini' version. The link above is corrected if you wanted to see all the specs at Chris' Coffee Service.
Jeff Sawdy
jesawdy
New Mini Vivaldi II by La Spaziale Vibratory pump
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by rlmerriam on Thu Nov 22, 2007 3:01 pm
I read spec sheet on the vivaldi mini and the specs indicate it has a vibe pump...is this correct?
rlmerriam
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by chris on Thu Nov 22, 2007 4:29 pm
yes
Chris Nachtrieb
chris
Woo Hoo!
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by Ron Sallee on Mon Nov 26, 2007 4:17 pm
chris wrote:The selling price is $200.00 less than Regular Vivaldi II.
And I could get it for $200 less than that as the winner of the Holiday Delights from Chris Coffee:
* $200 off purchase of La Spaziale Vivaldi Mini from http://www.chriscoffee.com. *
Except... I already have the regular Vivaldi II (purchased from Chris and I absolutely love it btw!)
Ron Sallee
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by Niko on Sun Dec 02, 2007 1:36 am
Love how it has holes for the drain kit! :D
Niko
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by IMAWriter on Sat Dec 29, 2007 3:09 am
Chris...would the vibe pump in the "mini Spaz" be quieter than that on my Anita?
Thanks...
IMAWriter
Link to "La Spaziale Mini Vivaldi II POUROVER dual boiler espresso machine"by chris on Sat Dec 29, 2007 12:32 pm
Yes the machine is quieter that an Anita. It is not the pump that is more or less noisy, it is the amount of vibration.
Chris Nachtrieb
chris
Return to Marketplace
