by Alchemist on Sat Jan 28, 2006 5:39 pm
I use a Zass DG 169, and have for about 4 years now. I use it both on my Gaggia Classic, and my Gaggia Factory and find it does the job it is meant to do. In order to use it well, you have to grind gentle. From what I can tell, there is no support on the lower end of the burr, so if you are huffing, and torquing, you can affect your grind. That said, it has gone head to head with a Rocky and a couple versions of mazzers and except that it is much slower (45 sec or so to grind a shot) the grounds were even and fluffy, with less static.
I keep wanting to mod my Zass to a motor or adjust the drawer so it can accept my pf basket, so I can dose right in, but so far I have not because I am an advocate of "if it isn't broken, don't fix it". Right now, I grind a little over what I think I need, and spoon the grounds into my PF gentle, doing my best not to disrupt the distribution too much (which I know I am). I found a chicago chop works best when I use my Zass, so after that, I level, load and pull.
I have heard recently that some of the current Zass's seem to have some quality issues with consistancy, but I know my 4 year old one is working great.
Good luck.
John Nanci
Alchemist at large
LMWDP #013
