gscace wrote:the device is at the cake and is the Ewenohoo device for sure.
I thought the name "Eponymous Device" was kind of cool, especially if there are any English majors or other folks who like big words reading this board.
But hey, it you want to stick with "Ewenohoo," it's OK with me.
gscace wrote: I was talking about the variance one see on the display, which seems to get pretty well attenuated by the time the water comes out'n da group.
Bill C's opinion was that 1 or 2 degrees variation where the temp probe is located (in the boiler) doesn't have much of an effect on the actual brew temp. It IS a marketing problem, though, because people who are paying $4500 not only expect to get stability, they expect to SEE stability on the display so they can brag about it to their friends.
The display variance is also a minor problem for the barista, because it's easy to forget what your setpoint is, and the display doesn't tell you without a lot of scrolling.
gscace wrote:And yes, the measurements suggest that the limit of taster sensitivity to temperature might be more than the 0.3 degrees. I'm guessing it's more like .6 degrees or so (root sum of the squares of 0.3 and 0.5 actually).
Sorry, I don't understand your point there. Could you re-explain it for poor old me? Thanks.
