jakline wrote:1. Are the GS3s still shipping with the sloppily drilled holes to make the tray fit?
The holes are okay on mine, not the greatest, but it's a very noncritical area and I don't see it causing a problem. The weight of the drain is minimal on this area of the frame, so it should cause a problem.
jakline wrote:2. It seemed a lot of of people with the Mazzer Mini Electronic (which I have) and the GS3 were unsatisfied and upgraded their grinder. Anyone happy with the Mini E and the GS3?
I wanted to get a step closer to the taste profile I get at Barefoot Coffee Roasters so I upgraded to a Rio Normalle. You can find used ones on Craigslist every now and then. The Bay Area is full of Coffee shops so you are bound to find one if you keep looking. I found a Rio Normalle from a guy who was shutting his store down in San Francisco for $365. It had new burrs and was used by Ritual Coffee Roasters in a Barista Competition. So it was a very special grinder.
jakline wrote:6. What is recommended for water? Currently I'm using Crystal Geyser per Jim Schulman's Insanely Long Water FAQ. Is that good enough?
I highly recommend if you are using bottled water, to go out and get a 5-gallon jug and a 1 gallon jug from Whole Foods. Now, fill your 5-gallon jug with water from one of the many local Pure Water or equivalent stores. Now here's the slightly tricky part. You don't want pure reverse osmosis water because it has practically zero hardness and doesn't optimize the taste for your espresso. Get a HACH 5B test kit from
http://www.hach.com. They are $14 plus shipping, etc and you can test the hardness accurately and many times with this kit. You basically want your water hardness to test to about 3 drops of from this kit which equals about 51 mg / L hardness. Once you get the kit you'll know what I mean. In my case I tested my tap water and it was something like 150 mg / L. With a little trial and error, I found that I only needed to add around 12 ounces of my tap water to a 1 gallon jug of Pure Water to come up with 51 mg / L hardness. So now I have taste espresso water that doesn't scale up my machine.
BTW, I work near the San Jose Airport, I can easily meet up with you on a lunch hour and bring my test kit. Just have some fresh coffee for us to try out.
jakline wrote:7. I'll likely switch from Illy beans to something else. I don't want to get into home roasting just yet, but I don't mind buying beans online and having them shipped once a week or so. Any recommendations from GS3 owners for a good bean to start with (will be shipped to Palo Alto, CA) and what temp. to use to start? (Note: I know this is a big subject. I'm not looking for the *best* beans, just a bean that works well for someone on a GS3.)
I highly recommend for you to visit the Barefoot Coffee Roasters cafe. Their cafe is located off of Stevens Creek and Lawrence Expressway. If you haven't been there, you should definitely make that a top priority for trying out new beans and getting inspiration. You can also pick up several bags of freshly roasted beans if you go on a Thursday or Friday. They usually stock their shelves on those days to prepare for the weekend. I like to go every few weeks and stock up on beans and since they are so fresh, you can easily throw some in the freezer to save you a trip. But the nice thing about going to the store, is you get exposure to the excellent Barista's, and you get 1 free double shot per bag. So go ahead and get 2 or 3 double shots for free while you are there. See what the blends taste like when they prepare it for you. Or bring a friend and treat him to some mind blowing shots of espresso. Barefoot also uses GB5's and they even have a temp probe hanging off the side of the machine most of the time. So feel free to ask the barista the temperature, extraction time, dosage or whatever. They are more than happy to tell you, even on a shot by shot basis. And they love to hear your feedback. It's actually very nice to have multiple shots there, because shots can very slightly from extraction to extraction, you can get once good shot and the next one could be incredibly good and you can find out from the barista what the behavior was for that shot and learn from them. I've definitely learned a lot from them.
I wrote a little bit about how I work my personally coffee supply. It could easily work for you too since Barefoot is also local for you.
roblumba wrote:So basically, try to find a roaster so that you can get it to your house so no more than 1 or 2 days old. Buy 2 or 3 lbs and freeze them in smaller 8 or 10 ounce jars. Now, your free to order beans from places that perhaps take 5 days to deliver. The beans in the freezer will be your buffer stash to hold your over until you order again from the more distant places. Right now, I have probably 2 lbs of Barefoot and 1 lbs of Ecco Caffe in the freezer and I'm going through 2 lbs of Klatch Coffee that took 4 days to get to me because I had ordered it on a Tuesday, they roasted and shipped on Thursday, it sat in a Fedex Wharehouse over the weekend and I received it Monday. But I don't fret about that kind of stuff too much because I have my buffer stash. However, I don't want my buffer stash to get more than 4 weeks old, so I'll probably wittle at my buffer stash for a while before ordering from Intelligentsia or some other place. And the cycle continues.
Also, I have small 8-ounce mason jars with the one way valve installed on the lids. So for this 2 lb order of Klatch Coffee, I've transferred 1 lb into the valved mason jars for immediate use, and the other pound is still in it's original unopened valved bag. When I finish the first lb, I'll put the second lb into the valved mason jars for immediate use. By minimizing the exposure of the beans to air, the shelf life is extended long enough for me to go through 2 lbs. The small mason jars work great. I had a jar that was Miller's Blend from Intelligentsia. It was nearly a month old and the crema and flavor were excellent. Granted, the crema was a little thin, but the body and flavor was very good. It behaved fairly well during extraction. I was quite impressed that this valved mason jar method can extend the shelf life for nearly a month.
