I have been looking for information on this machine on the internet, but there is very little to be found or at least I can't find someone that actually knows how it works. luckily there is still some parts available. I have found some drawings of its heads an boiler but it still does not explain its workings.
The first thing I don't understand about the M15 is that it has two inlet hoses - one going into the boiler where the head is attached to boiler, and one that goes directly into the grouphead. I know the machine should have a external pump but the previous owner misplaced it somehow. He also told me one can use almost any pressure pump since all that this pump does is to fill the boiler. The boiler has no auto water levelling device and this is done manually. He also clams that he plugged the second inlet straight into his normal plumbing cold water supply (±3bar pressure), and this is sufficient to drive the hydraulic heads.
To me this sounds wrong. I would imagine it the other way around with the external pump driving the hydraulic system and surely 4bar would be enough to be able to fill the boiler that runs on ± 1.2 bar of pressure. Please see the attached images
I also want to examine the possibility of converting the machine from three phase electricity to single phase. I am sure it can be done since it is only the boiler element and the very old pressure switch controlling the element that runs on electricity.
I am thinking of stripping down the whole machine and descaling everything but I would first try to get it running just to be able to assess what needs to be replaced and what it will cost.
If anyone knows anything about this machine please let me know.
