No problem Will, I understand that it's a grey area of netiquette, i.e., posting the same question to several sites. There's some overlap in the online communities these sites serve, so I recommend posting to the one that best suits your question (e.g., CoffeeGeek has forums for regional events, HB has the Marketplace forum for vendor announcements and On the Bench for research blogging, etc.). If your question is broad enough that it could be addressed to any of several sites, post to the one you frequent most often.
PS: The lever has a detent (hump on the cam) that should offer enough resistance to keep it in place. It will probably loosen up after a few shots lubricate the expansion chamber valve assembly (see
http://coffeeparts.com/futurmat/fut1.html for a detailed exploded diagram).
