jesawdy wrote:Maybe, maybe not. How accurate is your temperature reading? Meter? Thermocouple? Calibrated? And finally would the outside boiler temp equal the internal temp? (Of course it should be close)
1 bar (Patm) + 1.5 bar (Pg) = 2.5 bar which corresponds to 261F on the saturated steam tables.
aaaaah
hmmmmm
250F - 1.05Pgauge
261F - 1.48Pgauge
so a difference of .5 boiler Pgauge bar only yields 11F
But it seems more like raising .25Pg gave me a rise of 15F....
Accuracy - K tc on a Fuji Pid being used for temp read only. Fine wire K - bare wires twisted on end.
tc is under scotch double sided tape pad stuff so it acts as a bit of an insulator, with insulation over that. tc is attached to bottom of boiler.
tc checks out at 32.6 and 212.5
What started this was I am questioning the accuracy of the boiler gauge and wanted to """calibrate""" it.
The other prob is that my Mater seems to want to have a .3 or .4 deadband and probably needs replacing, but since it works I'll just leave it (I took it off and checked the microswitch, but all looks good. But it's 4 years old.)
Put it back together and running
1.20bar ON 240F
1.45Bar OFF goes up to 245.5
But I have no idea of the accuracy of the gauge.
