Is there a purpose for the E61 middle brew lever position?
Link to "Is there a purpose for the E61 middle brew lever position?"by FireguySpro on Fri Mar 23, 2007 4:49 pm
This may be a stupid question, but is there any purpose or reason for the lever to be half way from the off position to the brew position? I haven't found a use or any info anywhere regarding this. This pertains to any HX machine I suppose but my question is about the Anita's lever.
Thanks,
Alan
"Try before you pry" & "Brains are slippery"
FireguySpro
Link to "Is there a purpose for the E61 middle brew lever position?"by cafeIKE on Fri Mar 23, 2007 5:27 pm
This E61 pictorial should help.
In the middle position, neither spring set is loaded and both gaskets are seated.
cafeIKE
Great diagram
Link to "Is there a purpose for the E61 middle brew lever position?"by FireguySpro on Fri Mar 23, 2007 7:01 pm
I sort of understand what I see but exactly what is the point then of having the lever half in the middle? Is this a true position that serves a purpose?
FireguySpro
Link to "Is there a purpose for the E61 middle brew lever position?"by HB on Fri Mar 23, 2007 8:45 pm
If your machine is fed by line pressure, you can use the middle lever position to "prewet" the coffee puck. An interesting discussion of this here and excerpted below.
_______
olypdd wrote:You make an interesting point, but in the case of my machine, as soon as I engage the pump, the water is pumping out at what would appear to be enough pressure to hit the puck with a fair amount of force, vs a mere preinfusion (passive release of static line pressure). When there is a loaded portafilter in the machine, it does ramp up to brew bar in a matter of seconds. When I raise the brew activation lever with the machine off, water runs out the brew group at a leisurely trickle, that which would appear to saturate the grounds in a manner consistent with the idea of preinfusing them in a way so as to not disrupt the integrity of the tamp, and to counter the ability for water at brew pressure to channel along side the puck, vs saturating it uniformly.
Perhaps I misunderstood what exactly "defines" preinfusion as it relates to the operation of an E-61 brew group, but based on what I have read, and derived from speaking to Chris Coffee, it seems reasonable that initial soaking of the grounds at just over static pressure vs live pump pressure provides less invasive pre-infusion.
I did a little experimentation as documented in The Secret Life of Ristrettos, excerpted below:
HB wrote:While my comment isn't directly related to this thread, lately I've been experimenting with extraction rates as part of the Vetrano wrapup. That, plus Ken and Jim's The Impact of Preinfusion on the Taste of Espresso Shots has me thinking about extended preinfusion for E61s, despite their native capability.
Combining the two ideas, I increased the water inlet pressure to three bar. When the lever is up and the machine is off, water flows readily through the grouphead. The "rebound" time for the Vetrano is 30 seconds after the flush, so I reserved the last 10 seconds for additional preinfusion. Specifically:
  • Flush as usual; start preparing the portafilter (or prepare basket separately and drop it in later)
  • Lock in the portafilter
  • The heating element will click off 15-20 seconds after the flush; once it does, turn off the machine
  • At the 20 second mark, lift the lever up. The mains pressure will preinfuse the puck ever-so-gently
  • After 30 seconds, turn on the machine. Since the lever is still up, the pump begins immediately.
So what does this have to do with ristrettos? Getting the grind perfect for ristrettos on heat exchanger espresso machines can be tricky. Too slow a flow and the HX will overheat, producing a doubly-bitter shot (partially from high temperature, partially from overextraction). Too fast a flow and the rich, sweet, punchiness of a ristretto can be lost. The extra preinfusion appears to increase the margin of error.
As a rule of thumb, ten seconds of (extra) preinfusion equals a grinder adjustment of two millimeters coarser on the Mazzer Mini, or a reduction of coffee equal to approximately 1.5 grams (*). Running the mega-sized preinfusion "softens" the puck and opens a wider window for good extractions. My results so far for ristrettos are improved, though the opposite occurred for regular doubles, where the flavors became muddy and flatter.
(*) Don't take these numbers too literally, they are meant to convey that the effect is very small.
The machine off-on trick avoided any quibbling about the "3/4" position being used for preinfusion. I'm not convinced of the merits of this approach, but it's worth further experimentation.
olypdd wrote:Wouldn't the same ramp up to pressure there serve to preinfuse the coffee as you mentioned with the E-61. In fact, it seems to ramp up more slowly than my Vetrano rotary pump, but I haven't timed the two. Perhaps I will do this.
It's not easy to compare different grouphead designs; adding different pumps makes it even more challenging. That was a surprising lesson I learned in Pressure profiles, preinfusion and the forgiveness factor, i.e., the assumption that a slow pressure ramp up = preinfusion = high forgiveness factor isn't true. I thought it didn't make sense, but several others (including Jim) have confirmed my findings that the A3, which ramps up as fast as a rocket, is a forgiving espresso machine.
RapidCoffee wrote:Yes, prewetting may provide a more even extraction because it allows the coffee grounds to expand and fill in cracks in the puck. But you'd be better off fixing the grind/dose/distribution/tamp defects that produced those imperfections in the first place, and only then play around with pre-preinfusion. Note that Dan used an extended preinfusion for reasons of taste, not to fix channeling.
No offense intended. We all go through this with the bottomless PF. It's a great tool for improving espresso technique - and teaching humility. :wink:
________
John
Link to "Is there a purpose for the E61 middle brew lever position?"by DaveC on Fri Mar 23, 2007 10:10 pm
FireguySpro wrote:This may be a stupid question, but is there any purpose or reason for the lever to be half way from the off position to the brew position? I haven't found a use or any info anywhere regarding this. This pertains to any HX machine I suppose but my question is about the Anita's lever.
Thanks,
Alan
No intended purpose or reason, other than, presumably, ensuring one valve is fully closed before the other opens. However, if your pump switch is adjusted "correctly" you can make use of it.
When backflushing with cleaner, you can keep the pressure in the group for a while (pump running), then lower the lever to release the pressure. Out comes a lot of the cleaning agent....so does a reasonable job.
If the group is a bit dirty or you want to deep clean behind the shower screen and upper part of the group, then the half way position can be useful as it maintains much of the pressure in the group and can allow you to "bathe" the shower screen in cleaner for a minute or two (without the pump running).
DaveC
Link to "Is there a purpose for the E61 middle brew lever position?"by RapidCoffee on Fri Mar 23, 2007 10:22 pm
DaveC wrote:If the group is a bit dirty or you want to deep clean behind the shower screen and upper part of the group, then the half way position can be useful as it maintains much of the pressure in the group and can allow you to "bathe" the shower screen in cleaner for a minute or two (without the pump running).
A good idea. Presumably you can achieve the same result by turning the machine off and flipping the lever all the way up.
John
RapidCoffee
Link to "Is there a purpose for the E61 middle brew lever position?"by cannonfodder on Fri Mar 23, 2007 10:31 pm
I have been using the middle position as a soak stage when backflushing for years. I will let the pump pressurize, then lower the lever to the middle position, then very slightly to the down position. Just enough to let a little solution push up through the group. Then let it sit for a moment before dumping the pressure. Then I run the normal on/off sequence to flush the group.
I always assumed that the center position was for preinfusion for a machine that was attached to mains.
cannonfodder
Link to "Is there a purpose for the E61 middle brew lever position?"by RapidCoffee on Fri Mar 23, 2007 11:10 pm
That's right, thanks for the reminder: I'm assuming a machine that is directly plumbed. Otherwise there will be no line pressure to force water through the group with the power (or pump) off.
On my Vetrano, the middle position engages the pump before allowing water to flow. The pump switch is not easily adjustable (yes I checked). So in my situation, turning the machine off (as Dan suggested above) is the simplest option.
John
RapidCoffee
Link to "Is there a purpose for the E61 middle brew lever position?"by HB on Fri Mar 23, 2007 11:13 pm
For the benefit of those who are wondering what these valves look like, a few diagrams from Lino. Please do not copy these images.
The first image shows the E61 lever at the rest position. The two lower valves are open to allow the brew chamber and expansion chamber to drain. The uppermost valve is closed. Water from the HX circulates through the upper port on the left, passes alongside the "mushroom" to heat the grouphead; as the water cools it descends through the lower port on the left. The temperature difference creates a thermosyphon that circulates water between the boiler and grouphead.
The next image shows the E61 lever at the mid position. The two lower valves are closed and the upper valve is barely open. If this pump has line pressure, water will flow through the upper port, grouphead cap and screen, gicleur (yellow), descend towards the brew chamber (orange cam), and finally through the L-shaped channel to the brewhead. It's easy to see the purpose of the Allen screw (gray); it caps the hole drilled during manufacturing for the first leg of the channel.
The final image shows the E61 lever in the brew position. The upper valve is held open by the orange cam. The valve at the bottom of the expansion chamber is held tightly closed by a spring. The spring above it holding the second valve closed is weaker; it will open at about 4 bars of pressure. It only takes a second or two for the brew chamber containing the orange cam to pressurize. As the pressure builds, water eeks pass the valve below the orange cam, allowing the pressure to drop. This action is the novelty claim of the E61 patent since the pressure is automatically lower as the expansion chamber fills. Once the lower chamber fills, the pressure equalizes in all chambers and the valve below the cam closes.
The familiar "whoosh" that follows the lever being lowered is water evacuating the brew chamber and expansion chamber. Again at rest, the expansion chamber and brew chamber are empty. Water continues to circulate along the jacket of the uppermost chamber as the thermosyphon re-establishes itself.
Link to "Is there a purpose for the E61 middle brew lever position?"by scottyg514 on Sun Mar 25, 2007 9:03 pm
I'll tell you what I use the lever in the middle position for...
So that I can clean all the spots of coffee underneath the lever off the face of the machine due to channeling.
scottyg514
Link to "Is there a purpose for the E61 middle brew lever position?"by cafeIKE on Tue Mar 27, 2007 12:58 pm
HB wrote:The next image shows the E61 lever at the mid position. The two lower valves are closed and the upper valve is barely open.
More properly : The next image shows the E61 lever raised just above the mid position. The two lower valves are closed and the upper valve is barely open.
Not all e61s open the upper valve in the neutral mid position. Some have a neutral position where neither valve is open. This is shown on machines with a brew pressure gauge. After the shot, and the lever is fully lowered to release the brew pressure, the brew pressure gauge retains the brew pressure. This pressure is held until the lever is raised above the neutral mid position. If the upper valve opened in the neutral mid position, the pressure would drop as soon as the lever entered the neutral mid position.
cafeIKE
Link to "Is there a purpose for the E61 middle brew lever position?"by malachi on Mon Apr 02, 2007 1:17 pm
With a little "work", you can set up nearly any plumbed in E61 machine to do really good, manual soft pre-infusion this way.
With some coffees, this seems to result in significantly improved mouthfeel and overall experience.
malachi
Return to Espresso Machines
