by Grant on Thu Feb 28, 2008 6:45 pm
First, being venison, I would be more inclined to marinate is VERY well first. It's very lean and the marinade helps with moisture content, but also depending on what the animal was eating, I usually find the taste too gamey (for my liking) and a good marinade helps with that. I am more partial to buffalo/bison/ farm raised elk.
Also, venison typically needs to have some sort of "good tasting" fat added (again, to help with moisture and taste) and any venison fat carefully removed (as it tastes horrible).
That said, between the marinade, and then other fat for cooking, the coffee rub may not be a good match, but if you are so inclined, a really hot, fast searing on the grill to sear/seal in what juices it has, and then a slow rise to your desired finish may work.
Also, game meat is often served with a wine/berry based sauce, which grilling (without a pan) does not lend itself well to, as opposed to pan searing which leaves juice/drippings behind.
Grant Thompson
The Coffee Philter
