MOSFET wrote:At least on my machine. I am using a primitive form of preinfusion where a time delay relay delays pump turn-on, adjustable from 0.1 to 10 seconds. So unregulated mains pressure is used to preinfuse. I have 6 bars of mains pressure, so the pressure is high during preinfusion and coffee sometimes starts to drip out before the pump engages. When I turn off the preinfusion a lot of bitterness and muddy flavor goes away. So I'll either not preinfuse or add a regulator. But in my opinion preinfusion may help prevent channeling and probably does not improve flavor otherwise. Now that I have lots of tamping practice, a good tamper, and a good basket, I don't get channeling anymore, so I don't consider the preinfusion necessary. I'm sure this has been discussed but I haven't followed much discussion on preinfusion.
Keith
In the testing that Jim S. and I did, with my Cimbali Jr. D machine, we found that you needed 3 bar, at least, to preinfuse the entire puck thoroughly during a 6 second period. Anything less we tested failed to accomplish this goal.
Being as "typical" regulated pump pressure is around 9 bar, I would argue that 6 bar for preinfusion isn't "preinfusion" at all, but "infusion." You may be demonstrating that 6 bar, at least with your machine, your beans and your taste --- isn't a very good espresso infusion pressure, something that many of us would guess if asked, even though we probably haven't tried it.
My impression is that 6 bar preceding 9 bar does not accomplish much. Also, if your machine incorporates some degree of preinfusion in its design, the benefit of adding a delay timer is probably very limited.
ken
p.s. I would also argue that a moderate amount of barista skills may prevent channeling on some machines, and may be less successful on others. In a rotary machine which has a near instantaneous pressure ramp up, such as mine, moderate skills are not going to cut it consistently, although great skills likely would.
