Hi Mark,
Now that you've used this kind of insulation, you can see why it's so nice to work with compared to say fiberglass.
I thought about that when working around the corners and trying to fit the damn sheet inside the machine. I can't imagine working with fibreglass, expecially without the proper equipment.
I've took care to place the wires so that they don't touch anything except the foam. I still have to add two wires in the middle of the boiler to hold the middle part of the foam around the bottom of the HX, but other than that it all sits nicely. I might stitch the round piece around the heater, because at the moment it's simply squized into place, although it looks like it's not willing to fall out.
I'm really curious how good it's going to work as I was amazed to see the boiler still quite hot even after few hours from the moment I turned it off.
Anyone thought of using thin pipe foam insulation sleeves on some of the pipes in the machine?
Regards,
dsc.
