Fr. John wrote:Anyone ever see an inline gallon counter? I just bought a softener and filter kit from Chris Coffee and was thinking it would be nice to have a simple volume counter to keep track of when things need to be changed.
Chris has one he sells but unfortunately it is useless for low volume applications like a home espresso setup. If I remember right, the one I bought gave no indication of how many gallons passed through it until it started beeping, and the lowest number of gallons that it could be set to beep after was a couple of times the capacity of my softener cartridges. Chris let me return it, which I did.
If you are going to use a softener cartridge the best approach is to buy a jar of water hardness test strips; Mcmaster.com sells them in jars of 50 for less than $10 (I think it is something like $6 or $7). Estimate the amount of water you are running through the cartridge daily by taking the average amount of water you pull through the machine with each shot, and allow for any flushes before and after and also for regular backflushing. Divide the capacity of the cartridge in volume by the daily usage and you will get an idea of how many days, weeks, months each cartridge should last. Everytime you change a cartridge, take a test strip and confirm that you are getting soft water from the input to the machine (do not test the water that comes out of the machine, which may already have precipated scale in the boiler or on the heat exchanger and could therefore give a factitiously low reading). Then, make a notation on your calendar when you estimate that maybe 75 to 80% of the capacity of the cartridge is used up. From this point further, test the input water every week to be sure that you are still getting soft water and at the first hint of increasing hardness replace the cartridge.
Alternatively, consider softening the water in your entire house, which is what I've ended up doing. I'd already replaced a couple of faucet valves, a couple of toilet mechanisms, and was having scaling problems in showerheads and faucet aerators. If the water in your area is quite hard (mine is 11.5gpg) then what you are trying to prevent from happening inside your espresso machine is also happening in the plumbing throughout your house, and it isn't such a great thing and will cost you money over time. If you do soften the water in your whole house be sure to soften both the cold and hot water circuits, and try to exclude the outside water taps and any irrigation system you may have such as for your lawn and or trees from the softened water circulation. If your tap water tastes good, also consider having a tap put in before the softener, so that you can draw off drinking water into jugs. You don't want to drink a lot of softened water, which has a fair amount of sodium in it and generally tastes flat.
You could of course opt for a more complicated and expensive water treatment setup for your espresso machine but the benefits in taste and crema compared to cation softened water are not as great as some would insist.
ken
