Tink wrote:I usually drink about 2 caps or lattes a day.
Heidi,
Here is my logic - see what you can do with it and make up your mind.
If you weren't milk-dependent, choices were easier ...
Now you have the steam issue: steam is very hot in the espresso machine (way over 200F).
This relates to the technical architecture of the machine.
One boiler (1), two boilers (2) or one boiler with heat exchanger (3).
(1) espresso is made at one temperature setting of the machine, steam at the other.
You can make an espresso at one setting, switch over (wait for the machine to heat up properly), steam milk, and switch back to normal. The espresso is cold now (taste?). The entire routine is a bit of a hassle.
(2) one boiler with its own temperature regulation delivers steam, the other espresso water. A few home and most commercial machines are like this.
(3) the heat exchanger (HX - a tube) in the steam boiler delivers water at coffee temperature. During idle time the water in the HX may become too hot, so you need to flush a little water prior to making coffee. Many of the prosumer machines discussed here are HX in fact. If you browse through these fora you will see some discussion on tweaking or rituals. You should be prepared to do that.
Be aware a simple steam (no pump) based lever machine requires ritual too, or probably any machine for that matter.
Tink wrote:I would like to purchase a machine that will last for a long time. I do not want to upgrade in the future.
The sum of your desired grinder and the machines on your long list is serious.
Add a few things to the equation. You may want better baskets and portafilter (I bought La Marzocco and think it is better). Training budget so you do not feel guilty about initial coffees you may need to throw away.
Tamper. Digital 0.1 gram scales. Digital thermometer. Milk stuff. Minor details, but altogether these may run up to USD 200.
Carefully consider two things: plumbing in and pump.
Two cups a day is not much, but what if you need to replace water in a tank each time to make sure it is fresh? Plumbing in means the machine is on the water mains and, depending on the machine, could be drained to the sewage as well. But you may need to drill holes in your sink, etc.
Professional machines have rotary pumps - these are silent and have a constant flow rate that does not build pressure slowly as a vibration pump does (I assume). They are big and in commercial situation not even built into the machine, but under the sink, usually. However silent.
Tink wrote:I'm looking at buying a macap m4 or mazzer mini grinder.
Watch out for grinders with a doser chamber. You want to only grind the amount of beans for your single cappa. The doser chamber requires cleaning in order to remove stale old grinds.
Tink wrote:La Pavoni Lever
Alexia
Anita
Andreja
Elektra Micro Casa A Leva
Vivaldi
Ponte Vecchio
Bezzera
Fiorenzato Bricoletta
Vibiemme Domobar
I bought the Andreja Premium through Chris Coffee and do not regret these choices.
Would I have to buy a new machine today, given current market, my developed experience, would I buy the same machine?
At the time I bought Andreja I still considered milk/steam, but not anymore; so dual boiler or HX is no longer a requirement (milk protein health issue).
A (bit) cheaper alternative to me would be Quick Mill Alexia with PID.
I would still consider rotary pump and plumbing in as an option, and I would consider Izzo Alex for that matter. HX with plenty steam and a very easy path to plumbing in/draining out, or stand alone with large enough water tank. If I knew for sure it would be plumbed in an never needed to be run off a water tank, I would probably settle for Quick Mill Vetrano.
Andreja is still the best looking of all IMO. Excellent Wife Acceptance Factor (WAF). If you need to steam milk it has a few pro's many other machines do not have you might find really very important: no-burn steam-wand and professional valves (faucets) that do not wear like the cheap ones.
Internally, all these machines have essential (i.e. moving or wearing) parts you will also find in professional machines.
Some of the tech talk in this site is about the pressurestat in HX machines where Sirai is a real big professional thing that you do not find in many of the prosumer machines (not enough space inside or they want to keep the price down). It might be a bit more reliable, and is discussed as if more precise, but the numbers I have seen in specs, if I remember well, are all the same. When I needed to replace a vacuum valve in Andreja, after a few years because of an aged rubber O-ring in the valve, I also replaced the pressurestat by one that is a bit more expensive thinking it might last longer - but coffee remained as excellent as before.
And all this because I want a divine espresso twice a day.
Regards
Peter
Netherlands
Europe
