by mteahan on Fri Dec 02, 2005 10:17 pm
You should expect this, or any other large conical grinder to be quite expensive. If it really is a 63mm conical, it is only 5mm smaller than a Eureka and Rossi, and will be priced in that same ballpark. Probably double that of a Super Jolly and more than a major.
There is still not a reasonable mid line conical that I am aware of. The motor necessary to churn a 60+mm mill at sub 400 rpm is not cheap, and Macap is not crap.
This may not yet be the droid you are looking for.
Over half of the manufacturers in Italy produce conicals--there is no shortage. The shortage is over here.
Michael Teahan
Espresso Part Source
