I noticed that the Hottop and i-Roast profiles are quite different. The Hottop starts at a low temperature and ramps up very slowly and continuously over a relatively long time and takes 15 plus minutes to complete a roast. The i-Roast heats very quickly to a higher temp and then tends to level off, with a shorter overall roast time of around 9 minutes. Here is a typical comparison of roast profiles for a few machines (including the i-Roast and Hottop):
From previous experimenting with a defective i-Roast that ran too hot I've discovered that the i-Roast doesn't really do what it purports to do. The temperatures you program aren't the temperatures that are reached in the roasting chamber. In fact, it often gets hotter slowly over time. Also, the onboard temperatures that the machine reports are typically a lot lower than the temperatures measured using a thermocouple inserted into the center of the deflector.
So, I thought I'd try programming the machine to the minimum temperature for the maximum time (that's 325 degrees F for 15 minutes). I measured the temperature with the onboard thermometer and a thermocouple. I used 2/3 cup of Colombian beans (wet processed to avoid chaff buildup that would tend to increase the temp faster). The results are pictured below:
As you can see the result is a lot closer to the lower longer ramp up of the Hottop. First crack occurred at around 9:00 remaining and second crack at around 5:00 remaining. I stopped the roast at 4:00 remaining (for a total roast time of 11:00).
I tried the same thing the other day with some Brazilian beans (but didn't bother to measure the temp since I wasn't even sure the experiment would work). I didn't tell my wife that I did anything different and she commented on how much better the coffee tasted! So, that's what led me to measure the temps and try it again. I'll try to post some comments on how this batch tastes in a few days.
Has anyone else discovered any preferred profiles for the i-Roast?
Cheers,
Ken
