www.dailygrind.com: artisian roasted coffee and espresso equipment
HX Heaven or 1½ Boiler
Link to "HX Heaven or 1½ Boiler"by cafeIKE on Tue Apr 15, 2008 8:17 pm
About 18 months ago I added a PID to my Vibiemme Domobar Super.
It's great. I can pull shots without any flushing.
As there's never a free lunch, steaming capability is non-existant at 0.5bar and its a PITA to run the PID set point up and down like a YoYo.
To solve the problem, I added a small 12v DC power supply controlled by the pStat.
The 12v connects to one side of a SPDT toggle switch and the PID output to the other.
The common terminal connects to the SSR input.
When I need steam, I just flip the switch and the boiler quickly runs up to 1.3bar, providing ample steam. At a recent dinner party, I was able to make 3 lattes and a cappa, all doubles, in under 6 minutes.
When I'm done steaming, just flip the switch back and the boiler idles at perfect shot pulling temperature.
cafeIKE
Link to "HX Heaven or 1½ Boiler"by seattlesetters on Tue Apr 15, 2008 8:35 pm
That's a very elegant solution, Ian. Nice work!
seattlesetters
Link to "HX Heaven or 1½ Boiler"by GC7 on Mon Sep 22, 2008 9:40 pm
cafeIKE wrote:About 18 months ago I added a PID to my Vibiemme Domobar Super.
Sorry to bring up an older thread Ian but I'd really like to know what range of tempratures you set your PID to get good shots without flushing.
I have an Anita with PID and EricS thermometer at the grouphead.
At 211* PID temperature the grouphead at the thermometer reads 178.5* (~33* differential) and when I pull 2-3 oz of water (no flush) the thermometer goes up to the mid 180's and the (preheated with boiling water) glass measures upper 170's using a digital meat thermometer.
At 221* PID the grouphead steady state temp at the thermometer is 188* (33* differential) and when I pull 3 oz of water (again no flush) the grouphead thermometer reaches 196* (briefly and then down to 194) and the cup temperature is 184.5*
At 231* PID (this is right between 0.45 - 0.5 bar on my pressure gauge) the grouphead temp at the thermometer is 196* (~35* differential) and when I pull 3 oz of water (again no flush) the grouphead thermometer reaches 206* (briefly and then down to 203*) and the cup temperature is 190* This seems reasonable.
At 245* where I have the PID set normally and I use Eric's flushing recommendations the steady state grouphead temperature is 209.5* (about 36* differential)
I know that I need to get a brew temperature between 197* to 203* or so but I'd love to hear what works for others to get great coffee and I'd be curious to see what my numbers correspond to with regard to actual or approximate brew temperatures in the above simulated shots. I was told to try 211* but this does not yield good tasting espresso and my numbers above seem to indicate too cool brewing). Am I correct here?
Many thanks in advance.
GC7
Link to "HX Heaven or 1½ Boiler"by erics on Tue Sep 23, 2008 8:53 am
Geoffrey -
Firstly, where are you in NY - NYC? - as I certainly get up there every once in a while. Also, there are always updates to the manual for the digital thermometer at: http://users.rcn.com/erics/
I ASSUME you are trying to operate Anita with no cooling flush and your drink of choice is a straight espresso between 1.50 and 1.75 ounces. With that in mind, your 3 ounce flush is really a screen cleansing operation and should take place immediately AFTER you brew your shot, NOT prior to brewing a shot. Adjust your PID such that group temp reads 198-199F and try some shots there. It will take maybe 30 minutes to stabilize at any new temp and probably 10-15 minutes between shots.
Can you provide some pics/details of your PID installation?
Skål,
Eric S.
erics
Link to "HX Heaven or 1½ Boiler"by GC7 on Tue Sep 23, 2008 9:23 am
Eric
Many thanks for the response. Yes - I work in NYC and live just to the North in Westchester County.
I can get some photos by tomorrow but the PID is from Dave and says Delta on the upper left.
I am new to espresso so I am trying to get my techniques down and see what gives me the best results and closest to those addicting shots I had recently at the Blue Bottle Cafe in SF. I just got a new Compak K3 touch grinder which has helped A LOT. I have been using a 245* boiler temp and using your flush (185) and wait as well as a flush to 200* and go within 10 seconds or so. Both are OK. I would like to just be able to mindlessly pull my morning shot without any of that. I was told to try a 211* setting but that seems to be too cool.
The 3 oz. I mentioned are simply what I guessed would be used to make the shot without any flush so I measured that water with a digital meat thermometer in a preheated espresso glass. I do flush and clean the showerhead after every shot too. Given your statement to get the grouphead to a steady state temperature of 198 then I would need to keep the boiler at about 233-234* or so to pull a shot without any fluch at all. That would be just about the 0.5 bar that Ike quoted in the first post.
PS- Let me know if you will be in NY.
GC7
Link to "HX Heaven or 1½ Boiler"by CambodianBeast on Tue Sep 23, 2008 9:53 am
Geoffrey,
I have a PID Anita as well, and I love it.
Since you are new to espresso, why not start off with the "standard" HX flush technique before experimenting with lower boiler temps? The temperature stability of HX machines at full temp has been well studied, and this way you can get a good handle on what your current setup can offer - then you can compare the results of low-temp experiments to this "baseline".
I keep my boiler at 254 or 255 F, and use the basic technique suggested here: http://www.home-barista.com/hx-love-manage-brew-temperature.html. Basically: Anita warmed up 30 min, coffee ground and dosed, quick cooling flush to ~199 (~7 seconds after the end of sputtering), quick WDT and tamp, and GO.
The "water dance" is often made to seem more complicated than it really is, and after a few weekends of practice it can be as "mindless" as the rest of your morning routine.
CambodianBeast
Link to "HX Heaven or 1½ Boiler"by GC7 on Tue Sep 23, 2008 3:02 pm
Damian
Thanks for the reply. As I mentioned, I have been playing with different methods such as flush and go (your method), Eric's temperature probe flush and recover method and I'd like to try the no flush method for mornings where I just want one or two espresso's before going off to work. I was clearly held back by the Virtuoso grinder . I can see that clearly now that I have a first rate dedicated espresso grinder.
As a scientist I'd like to do some systematic measurements of what works best for my tastes. I am on the way thanks to all the advise I've received from Dave, Mary at Chris' Coffee and the good contributors to this forum.
GC7
Link to "HX Heaven or 1½ Boiler"by cafeIKE on Tue Sep 23, 2008 8:22 pm
GC7 wrote:Sorry to bring up an older thread Ian but I'd really like to know what range of tempratures you set your PID to get good shots without flushing.
No apologies necessary. Sorry about the tardy response. Notifications seem problematic at present.
My normal range of temperatures is 228° to 234°F, for a brew range of ~195° to ~198°F. The group thermometer idles a bit lower than the brew temp and rises above it at the start of the shot.
cafeIKE
Link to "HX Heaven or 1½ Boiler"by GC7 on Tue Sep 23, 2008 8:41 pm
Many thanks Ian
Your numbers are pretty well in line with how my machine is functioning which is comforting that all is well on my end.
I'll try to pull some shots in that temperature range.
Are you still using the no flush method or have you moved on to something else that is reproducible for you?
GC7
Link to "HX Heaven or 1½ Boiler"by cafeIKE on Tue Sep 23, 2008 10:11 pm
Pretty much No Flush all the time. If I do a bit of steaming for a party, I'll flush a little to keep the group under control.
What are your P I D parameters?
cafeIKE
Link to "HX Heaven or 1½ Boiler"by GC7 on Wed Sep 24, 2008 11:45 am
Ian
I have no idea how the PID is calibrated or setup. I left it exactly as Dave sent it to me.
I recall a discussion I read during my brousing/learning stage here where PID settings were altered to "improve" shot to shot consistency at lower boiler temps but I thought the end result was that it is not reeproducible.
GC7
Link to "HX Heaven or 1½ Boiler"by GC7 on Thu Sep 25, 2008 7:47 pm
I pulled a couple of nice shots at 233* today (grouphead temp of 198* on the thermometer).
I heated the glass with a couple of oz. of H20 and then grind, dose and pulled the shot. The first in the morning was Sweet Maria Liquid Amber Espresso 1.5-2 oz and this evening a ristretto of a FC roast of Ethiopia Idido Misty Valley. I think I'll try 1 degree warmer tomorrow.
Ian - here is a photo of my PID setup. Not sure what it tells you (certaily not its setting other then temp)but comments are welcome.
GC7
Link to "HX Heaven or 1½ Boiler"by cafeIKE on Fri Sep 26, 2008 12:06 am
Nice install. I was just curious if you'd done your own tuning and what you'd come up with.
Two years of e61 HX PID futzing have shown me a huge range of parameters return acceptable results.
Ignore the numbers and enjoy the espresso!
cafeIKE
Link to "HX Heaven or 1½ Boiler"by GC7 on Fri Sep 26, 2008 9:37 am
Thanks Ian
I have MANY things to futz with before I play with PID parameters where I have no idea what factor(s) each control. I'll learn my basic barasta techniques for now.
The 234* shots were a tad more bitter then the others so I will go a hair lower and see the results.
GC7
Link to "HX Heaven or 1½ Boiler"by uscfroadie on Fri Sep 26, 2008 10:02 am
Geoffrey,
Just curious...from your post it seems as if you are an espresso drinker more than a cappa guy. If so, why did you opt for Dave's PID'd Anita over his Alexia? I ask because I toyed around with the idea of a PID'd Anita or Andreja as a possible upgrade to my Alexia.
Thanks in advance for your input.
Merle
uscfroadie
Link to "HX Heaven or 1½ Boiler"by cafeIKE on Fri Sep 26, 2008 10:35 am
Merle, I had a single boiler with electronic control and investigated single boiler machines like Zaffiro before deciding a PID HX has all the advantages and none of the drawbacks.
cafeIKE
Link to "HX Heaven or 1½ Boiler"by GC7 on Fri Sep 26, 2008 10:51 am
Merle
I spent some time contemplating what machine to purchase and a number of factors came into play one of which is my ignorance of the whole topic :roll:
I read as much as I could about the various types of machines and the reviews of individual machines. The PID control of the boiler to me is a much more precise and quich way to regulate temperature and I guessed that the PID would have a lower failure rate (pressurestats from what I've read fail at a n alarming rate). The temperature stability and ability to change temperatures on the fly lets me pull shots without flushing as the topic of this thread implies. So, in that sense I can make the Anita into a pseudo 1 boiler and get good espresso.
In my reading I also liked the idea that using flushes and especially with Erics temperature probe thermometer for E61 groupheads I could easily vary my brew temperature and possibly even the profile. I can't say my skills are up to taking advantage of this capabibility of the HX but I like the idea that it is a flexible setup (in theory).
Finally, my fiance likes her cappas and we MUST keep the women of the house happy! :lol: We both love to cook and have company for dinner so the throughput capabilites came into play as well as my guests' might want milk based drinks too. I thought hard and actually at first selected the Alexia but in the end those factors, the small increase/difference in price and the thoguth that I did not want to feel the need to "upgrade" any time in the at least near future led to my selection of the PID'ed Anita. I'm happy so far but I have A LOT to learn. Good to know the knowledgable folks here on HB are willing to help!
Hope this helps.
GC7
Link to "HX Heaven or 1½ Boiler"by uscfroadie on Tue Oct 07, 2008 5:39 am
Geoffrey and Ike,
Thanks for the replies. I won't be upgrading until I move back to the US in January, so I still have time to ponder. In the interim, I have a Gaggia Factory 16 on the way which I could use on the rare occassions that I have friends over and need to make many milk drinks back-to-back. I figure I can use the Gaggia to steam while the Alexia brews the espresso. In essence this makes a double boiler, albeit in two separate machines. :D
Merle
uscfroadie
Return to Espresso Machines
