by giulio on Thu Feb 21, 2008 2:50 pm
Thanks to everyone for the suggestions: I am the end user having a problem with the Mazzer.
A few clarifications. My machine is currently a Pasquini Livia (and a Pavoni that I use occasionally, plus I am waiting for a VBM double boiler). The beans are decaf espresso (and dark espresso) from Full City Coffee, Eugene, OR, and they are fresh (3 to 10 days from roasting) and, I may add, quite good.
As was mentioned, the Le'lit produces, using decaf, a grind fine enough that, with proper tamping, I have no problem producing a 10 sec preinfusion for a total of 25-27 sec. The setting is far from the finest, and I can go finer with no choking. At this setting, there are no clumps.
Same beans on the Mazzer produce a slightly coarser grind at a setting of around 4-5 small notches finer than factory zero. If I tamp very very hard, I can get to 20-25 sec. At this setting, there are noticeable clumps. Moreover, any attempt to go finer produces choking. At slighly coarser settings, perfect grind: no choke, no clumps, symmetrical pyramid. But it is not fine enough (10- 15 sec). And it is not the beans - same story with Lavazza crema beans.
As recommended, I went through a lot of Lavazza beans trying to adjust the setting all the way up to coarse and back to fine. On the way back I got finer grind than before, but soon it was choking again.
I have not yet tried to clean the burrs.
Any suggestions?
