How to use a La Cimbali Liberty
A haven dedicated to lever espresso machine aficionados.
Link to "How to use a La Cimbali Liberty"by AngerManagement on Fri Apr 21, 2006 7:54 am
I have a 1984 La Cimbali Liberty (brass) that has been mistreated and I need some guidance.
While the tank has had plenty of scale and some pitting the rest of the system appears to be responding to lots of TLC.
O-rings and seals have been changed, the pressure thermostat has been fully cleaned and tested.
However when it comes to using it I get crap results.
Switch it on.
Let it heat up - about 0.3 bar and I can hear the thermostat switch in and out.
Open steam valve (knob) to steam milk.
Close steam valve.
Load portafilter with coffee
Tamp coffee ( If packed too high it fouls, 10 ml below Top of Basket - looks OK)
LOWER ARM to load brew head with water.
Count to 5 or 10...
Lift UP arm
At this point you should expect to have coffee / crema entering the cup ?
PROBLEM: Maybe ?
1: Lever on Spring return, goes straight UP with little resistance except for the last inch or two - 05 - 10 mL of Coffee and No Crema ? Just Dark brown fluid.
2: Manually control the lever return slowly and experience little resistance - 20 - 30 mL of Coffee and No Crema ? Just Dark brown fluid.
Have tried course and fine grinds as well as packing / tamping. Not sure just how fine the coffee should be with this unit. I am using a KG100 and have a few notches to go before at the bottom setting.
Further testing- Hot Water through the head and empty filter and into a cup = 89C - 90C so have to assume the temp is about right, but could go a little higher ?
I also noticed that the PF has a star pattern of larger holes and have never seen this before in the PF's that I have looked at ? Is this normal or has the previous owner attempted a modification of some type. Any guidance on this matter of these holes / status of the PF OR steps to get a better shot from this system would be most welcome.
AM
Ability is nothing without opportunity. - Napoleon Bonaparte
AngerManagement
Re: How to use a La Cimbali Liberty
Link to "How to use a La Cimbali Liberty"by hbuchtel on Fri Apr 21, 2006 8:37 am
It's possible that (for some reason) the chamber is not filling completely, can you try
AngerManagement wrote:Switch it on.
Close steam valve.
Count to 5 or 10...
Count to 20 or 30? (or more)
AngerManagement wrote:Lift UP arm
If this gives you more resistance and a fuller cup then this is probably your problem.
Henry
LMWDP #53
hbuchtel
Link to "How to use a La Cimbali Liberty"by timo888 on Mon Apr 24, 2006 11:19 am
Another test: grind to a Turkish powder and use a heavy tamp in a deliberate attempt to stall the machine. Report findings.
Timo
timo888
Link to "How to use a La Cimbali Liberty"by AngerManagement on Mon May 01, 2006 6:10 am
timo888 wrote:Another test: grind to a Turkish powder and use a heavy tamp in a deliberate attempt to stall the machine. Report findings.
Timo
Have obtained a second hand Basket and a Custom Tamper :-) As soon as they arrive I will be able to do some further testing..
Will keep all advised and hope to include a pic or two.
AngerManagement
Link to "How to use a La Cimbali Liberty"by AngerManagement on Mon May 01, 2006 6:17 am
Timo
AngerManagement
Link to "How to use a La Cimbali Liberty"by timo888 on Mon May 01, 2006 6:33 am
AngerManagement wrote:Have obtained a second hand Basket and a Custom Tamper :-) As soon as they arrive I will be able to do some further testing..
The test I suggested could be done with the old basket. When I'm using lighter roasts, my Peppina likes a very fine grind. A grind that worked fine in a Silvia and in an Olympia were as nothing to Peppina, and the shots were taking five seconds. So my test was designed to let you determine at which point (if ever) your machine stalls.
Regards
Timo
timo888
Link to "How to use a La Cimbali Liberty"by AngerManagement on Wed May 03, 2006 4:58 am
timo888 wrote:The test I suggested could be done with the old basket. When I'm using lighter roasts, my Peppina likes a very fine grind. A grind that worked fine in a Silvia and in an Olympia were as nothing to Peppina, and the shots were taking five seconds. So my test was designed to let you determine at which point (if ever) your machine stalls.
Regards
Timo
My problem is that I am also looking for the $$$ to be able to afford a good grinder. The KG100 is OK but it does not really grind as smooth as I would like when down at the bottom end.
THIS weekend, either way I will run some shots :-)
AM
AngerManagement
