www.vanelis.com: top-notch espresso equipment and customer support
How to remove the dispersion screen and gasket of an E61?
Link to "How to remove the dispersion screen and gasket of an E61?"by lasvegas on Sat Jul 16, 2005 10:07 pm
Am having a problem with the Isomac Rituale. The pf has been un winding itself while pulling a shot and wet grounds are going everywhere. Thought it was the pf and tonight though I would clean the screen and gasket while it was down. Turned the machine over and there is no screw in the screen which can be unscrewed to remove the screen and gasket. Turns out it appears that the gasket has shifted and no pf will lock until the gasket is rest into its correct position ? Looked on the top of the group head and there is no screw there. There is however an allen wrench slot at the back of the group head towards the body. Is this what is holding in the screen and gasket?
Question....how do I remove the screen and gasket in the group head on the Isomac Rituale?
Thanks
lasvegas
Link to "How to remove the dispersion screen and gasket of an E61?"by HB on Sat Jul 16, 2005 10:20 pm
If torquing the portafilter tighter doesn't seal, then the gasket is probably dry / worn out. Removing it without damage is possible, but it isn't easy. Let's begin with a short review: E61's are pretty much all the same -- the gasket is wedged in a groove and the gasket holds in the dispersion screen.
The article E61 Group Maintenancehas lots of pictures and instructions on how to clean and replace the grouphead gasket / dispersion screen. It suggests using an awl / pick to grab at the gasket, but I've squeaked it out with no damage two different ways:
  1. If you're lucky, the dispersion screen has a groove on the side that you can catch with a blunt screwdriver. Pry just a little every few inches around the perimeter, using the group for leverage (that's why I prefer the screen below on the right, it's easy to remove).
  2. Otherwise, try working a dull, thin, flexible knife blade (I use an old el-cheapo "Papered Chef" paring knife) along the inner edge of the basket, pulling the gasket downward and outward a little. Go around the perimeter; if you're patient, it will come out without damage in less than two minutes.
If the gasket is shot, then there's no need to worry about nicking it. Follow the article's instructions and reinsert a new gasket / screen.
PS: There are two types of dispersion screens for the E61. The "ungroovy" ones (left) usually have a thin metal ring spot-welded around the perimeter of the screen and a "dot" welded to the center, whose purpose is still a mystery to me. I've gotten both kinds off without nicking the gasket, but the ungroovy ones are more challenging (and I scratch the sides of them more ;-)).
PSS: Also see What is that ugly Allen screw for?
Link to "How to remove the dispersion screen and gasket of an E61?"by HB on Fri Jun 16, 2006 10:29 am
UPDATE:
I recently read two other suggestions on removing an E61 dispersion screen without damaging the gasket on CG. Kristi used a straightened paperclip with a small 90 degree bend on the end, wiggling it between the gasket and grouphead groove, then turning the paperclip to pull at the gasket from behind. Another suggested grabbing the dispersion screen with a pair of large ratchet jaw pliers and rocking it out gently.
Also see related thread: How to clean an E61 dispersion screen.
Link to "How to remove the dispersion screen and gasket of an E61?"by cannonfodder on Sat Jun 17, 2006 3:43 pm
While rebuilding my Faema, I removed the screens and gaskets a couple of times. I found that a paint can lid opener works wonderfully. You know, that funny short handled gizmo the paint store gives you for free when you purchase a gallon of paint. No damage to the gasket. I used it on the gasket, not the screen.
cannonfodder
Changing group gasket
Link to "How to remove the dispersion screen and gasket of an E61?"by Tazza d'oro on Sun Aug 27, 2006 3:59 pm
I think it's time to replace the group gasket on my Expobar Office Control. Never having done this in the past and there being no instructions on how to do this in the supplied manual, I'm looking for help. Is this a simple case of pry out the old and press fit the new or is there more involved? Additionally, as I'm using a naked PF by Lino, is it best to use the original size of 8.5mm or the 8mm advised by Chris Coffee.
Tazza d'oro
Link to "How to remove the dispersion screen and gasket of an E61?"by HB on Sun Aug 27, 2006 8:52 pm
Tazza d'oro wrote:Is this a simple case of pry out the old and press fit the new or is there more involved?
That's pretty much it. I merged your thread with this thread on the same topic to keep them in one place. EPNW's E61 Group Head Gasket Replacement Tutorial & E-61 Maintenance Tutorial includes step-by-step photos.
I used Lino's portafilter with the stock gaskets without problem on the Brewtus and Lever, which I believe share the same grouphead as your Control (confirmations or corrections welcome).
Link to "How to remove the dispersion screen and gasket of an E61?"by LeoZ on Wed Sep 06, 2006 9:15 pm
if i had to guess, the little nub in the middle of the dispersion screen is there to cover the screw/hole where the coffee comes from.
im going out on a limb, but im thinking that without it, the coffee wouldnt properly be spread over the entire surface of the screen. maybe the machines that use this style screen have a different type of screw in the head? if not.. wouldnt that mean switching it to a 'groovy' one would work fine?
PS- i had the same problem when i decided to look into my grouphead and screen. you really have to torque it, harder than you think. also, test with a backflush disk, it saves coffee and builds more pressure. :)
LeoZ
Link to "How to remove the dispersion screen and gasket of an E61?"by Tazza d'oro on Wed Sep 06, 2006 11:29 pm
I have a completely flat dispersion screen...no nub, no screws. I was wondering if I would be better off ordering a new dispersion screen at the same time as the gaskets.
Tazza d'oro
Link to "How to remove the dispersion screen and gasket of an E61?"by HB on Thu Sep 07, 2006 8:14 am
I wouldn't bother replacing the dispersion screen unless it's damaged.
Link to "How to remove the dispersion screen and gasket of an E61?"by Dogshot on Fri Sep 08, 2006 11:06 pm
I use a combination of 1) loosening the gasket by releasing the pf just as the pressure starts to build to 4-5 bar while pulling a blank shot with the blind basket, and 2) Cannonfodder's paint-can tool trick. It takes less than 2 minutes, and is very easy to do, even with a hot machine.
I made the mistake recently of getting distracted after brewing a shot and leaving the pf with the spent puck in the machine for an hour or more. Even after a standard Cafiza backflush treatment, here's what my screen looked like:
Moral of the story - it pays to remove the screen and gasket every now and then just to make sure things are as clean as they should be.
Mark
Dogshot
Removing Expobar group gasket?
Link to "How to remove the dispersion screen and gasket of an E61?"by Tazza d'oro on Thu Oct 12, 2006 9:45 am
The old gasket on my Expobar Office is really cooked. I've tried driving screws into it without success.
How can I remove it without doing any damage?
Tazza d'oro
Link to "How to remove the dispersion screen and gasket of an E61?"by HB on Thu Oct 12, 2006 10:01 am
Link to "How to remove the dispersion screen and gasket of an E61?"by Tazza d'oro on Thu Oct 12, 2006 10:07 am
Thanks...it's out. Now for a good cleaning and replacing with a new gasket. Actually I was afraid of damaging the head itself with the screws as it really required some hard driving to get a grasp on the really cooked old gasket. The method, suggested by the tech folks at WLL, was to insert screws at 3 & 9 o'clock and then use pliers to remove gasket. Perhaps, in the future, I shall remove the gaskets before they reach this stage.
Tazza d'oro
Link to "How to remove the dispersion screen and gasket of an E61?"by RegulatorJohnson on Mon Jan 15, 2007 11:12 am
Dogshot wrote:Moral of the story - it pays to remove the screen and gasket every now and then just to make sure things are as clean as they should be.
i was so afraid to clean behind the screen that i decided to not do it until later.
later came one day when the wife was making a shot and the entire screen and gasket fell out into the PF. there was so much gunk in there it pushed the screen off. needless to say that was gross.
i now remove the screen and gasket every weekend directly after the cafiza backflush, also weekly.
this is very simple and it will make you want to clean it out once you see what is back there.
jon
jon stovall
bevalo.com
thebeaningoflife.com
RegulatorJohnson
Return to Espresso Machines
