How To Make Your Own Naked Portafilter - Page 2
Link to "How To Make Your Own Naked Portafilter"by arossphoto on Mon Jul 17, 2006 6:09 pm
Fr. John wrote:I plugged the PF hole with a tapered dowel rod (tapered like a cork so it got tighter with pressure). That gave the centering bit something to bite into and stay centered.
Great advice! Did you use a drill press or just hand held?
Thanks.
arossphoto
Link to "How To Make Your Own Naked Portafilter"by Fr. John on Mon Jul 17, 2006 6:36 pm
Drill press. You can see the rudimentary jig I used in the photo I posted. It's basically two screws in a block of wood positioned to catch the flanges on the PF making it immobile.
Fr. John
Fr. John
Link to "How To Make Your Own Naked Portafilter"by CoffeeBeau on Thu Sep 21, 2006 11:27 pm
Thanks to Fr. John and the rest of the HB posters. I used a hole saw and drill press, then finished it off with a dremmel. Total elapsed time was about 20 minutes. Now I have to give it a go! :D
Bob
CoffeeBeau
Link to "How To Make Your Own Naked Portafilter"by Fr. John on Fri Sep 22, 2006 12:53 am
Beautiful. Just think how much you saved!
Fr. John
Fr. John
Link to "How To Make Your Own Naked Portafilter"by CoffeeBeau on Fri Sep 22, 2006 8:21 am
Yes, I saved about $50, plus I do not have a 3rd portafilter to clutter my espresso area up. Thanks again.
Bob
CoffeeBeau
Link to "How To Make Your Own Naked Portafilter"by HB on Sun Dec 17, 2006 2:32 pm
While cruising the net, I ran across the article How to make a Naked Portafilter for your espresso machine. Great instructions and photos, if you happen to have a metal lathe.
Link to "How To Make Your Own Naked Portafilter"by CoffeeBeau on Sun Dec 17, 2006 3:57 pm
Wow, intense. A drill press and a hole saw does the trick, but not nearly as fun as turning the PF on a lathe.
Bob
CoffeeBeau
Link to "How To Make Your Own Naked Portafilter"by HB on Sun Dec 31, 2006 11:50 pm
Yet another bottomless portafilter how-to using a standard door set 2-3/8" hole saw with nice photos.
Link to "How To Make Your Own Naked Portafilter"by Kristi on Mon Jan 01, 2007 3:34 pm
Back with Silvia I just drilled it out with a 2 3/8 hole saw - rough but effective.
After that I bought them - one from 1st-line, and next from Chris'
Kristi
Link to "How To Make Your Own Naked Portafilter"by DigMe on Mon Jan 01, 2007 11:21 pm
HB wrote:Yet another bottomless portafilter how-to using a standard door set 2-3/8" hole saw with nice photos.
Actually it wasn't a door-set hole-saw...or it wasn't noted as such on the packaging at least. I just mentioned a door for whatever reason. I only mention this because I think a lot of the door-set hole-saws are intended for use on wood and the one I bought was marked as being fine for use on metal as well.
bc
DigMe
Link to "How To Make Your Own Naked Portafilter"by DigMe on Mon Jan 01, 2007 11:26 pm
Fr. John wrote:
I feel cutting from the top down on the inside is easier and less likely to mar the PF than turning it over and cutting from the bottom up. The PF naturally holds the hole-saw in there where it can't get away from you and any marring that might occur would be hidden on the inside of the PF. The method I'm talking about is easy using a bench vise. See HB's link above to my instructions with pics which I posted on another board.
bc
DigMe
Link to "How To Make Your Own Naked Portafilter"by DigMe on Mon Jan 01, 2007 11:28 pm
arossphoto wrote:What size hole-saw did you use? I was looking at some at the hardware store today and some had a mandrel (a bit in the center to guide the saw) and some did not. My first thought was the mandrel would be important to keep the saw centered, but then I wondered if it would get in the way as the saw went deeper. Did you use a drill press or just hand-held?
Cheers,
Andrew
I know this was an old post but I wanted to clarify that the mandrel is NOT the bit that comes up from the middle of the hole saw. That is called a pilot bit. The mandrel is the shaft that the hole saw attaches to that keeps it attached to the drill. If you buy a hole saw that comes without a mandrel then you will need to buy one separately. The cheapest way will be to buy a mandrel/hole saw combo that come together.
bc
DigMe
Link to "How To Make Your Own Naked Portafilter"by Bigfella on Sat Apr 19, 2008 10:25 am
I just "modified" by La Pavoni Old Group portafilter and made it naked, in the never ending search for the perfect shot. Well I must have made a fubar because now the machine squirts espresso all over the kitchen - my wife is VERY happy about this - or it runs down the handle onto my wrist. Can someone help?? happy to post a picture of my efforts.
Its either make it work or £50 for a new one!
Bigfella
Link to "How To Make Your Own Naked Portafilter"by ppopp on Sat Apr 19, 2008 10:59 am
When I modified my SL-70 portafilter to go bottomless, I had trouble at first with the espresso running down the handle. Turns out that the clearance between the basket and the edge of the hole wasn't big enough, and the espresso was catching on the edge of the hole and running down the handle. I described it here:
http://www.coffeegeek.com/forums/...so/machines/286238
I fixed the problem by increasing the clearance (essentially making the hole bigger), and it gave the espresso more room to "crawl" to the center of the basket and then drop down.
Peter
Know beans, know coffee. No beans, no coffee.
ppopp
Link to "How To Make Your Own Naked Portafilter"by Bigfella on Sat Apr 19, 2008 12:39 pm
Excellent! Another 30 mins filing and all is well, almost. I pulled a nice shot but I still get some leaking on the the handle but it drips into the drip tray so it's not too bad. I have removed more metal from the handle area - should I be brave and remove some more or have I gone too far already.....Image
Bigfella
Link to "How To Make Your Own Naked Portafilter"by nixter on Tue May 13, 2008 8:57 pm
I found a machine shop about 3 blocks from my house. They drilled out the bottom of my extra PF for $40. Works great!
n
nixter
Link to "How To Make Your Own Naked Portafilter"by DigMe on Tue May 13, 2008 10:31 pm
nixter wrote:I found a machine shop about 3 blocks from my house. They drilled out the bottom of my extra PF for $40. Works great!
n
Wow...they charged you too much.
brad
DigMe
Link to "How To Make Your Own Naked Portafilter"by nixter on Tue May 13, 2008 11:17 pm
In terms of convenience it was an absolute steal. It's not worth my time to do it myself (ok I don't have the tools) and I didn't have to send it anywhere and deal with shipping and handling or waiting for a package to arrive. dropped it off, ran some errands, picked it up. $40 dollars cash. No complaints.
n
nixter
Link to "How To Make Your Own Naked Portafilter"by VS_DoubleShot on Sat May 17, 2008 4:19 pm
i just noticed espressoparts is selling used portafilters made naked for $20 a pop
VS_DoubleShot
Link to "How To Make Your Own Naked Portafilter"by Spresso_Bean on Sat May 17, 2008 4:37 pm
VS_DoubleShot wrote:i just noticed espressoparts is selling used portafilters made naked for $20 a pop
Just to add to this - the used portafilters are for E-61 type groups. Not a bad deal but it also states the condition may vary.
Spresso_Bean
PreviousNext
Return to Espresso Machines
