How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by TimEggers on Tue Dec 25, 2007 12:44 pm
I received a very nice surprise when I opened my LM portafilter, what a nice portafilter! I also had one of the thinner 8mm gaskets but even with that the portafilter would not tighten any tighter than the 7 o'clock position (with appropriate resistance).
I didn't want to hack at this beautiful new portafilter and I dreaded a mod that would be visible. Why make such a nice looking piece of equipment look ugly?
The solution was simple first I gathered the tools I would need: (All-purpose sand paper sheet)
By holding the portafilter it was easy to sand off the top lip of the portafilter to shorten the length between the basket rim and bottom of the portafilter ear. Other modifications that I saw involved milling the ear leaving raw brass exposed. I didn't want that look.
Here my other hand is holding the camera, but you get the idea.
The results after about 10 minutes (its slow but you'll have complete control and end up with a clean and level edge!
Having done this I've seen that not too much is needed to be taken off. Above is the finished product and now my Quickmill double basket, Synesso triple ridgeless and LM double fit wonderfully (with or without the portafilter spring). Also the best part is the filter basket completely covers the modified edge (which if using a sandpaper fine enough will be smooth and very even). You could use a coarse then finish with fine grit too.
The portafilter should now fit perfectly!
Tim
LMWDP #202
TimEggers
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by cannonfodder on Tue Dec 25, 2007 4:40 pm
The Scace II is built on a bottomless LM portafilter. The lugs were a hair too long to fit the group in my Elektra. I trimmed the length and rolled the edges and thinned the lugs, then polished it all off using a Dremel.
cannonfodder
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by TimEggers on Fri Feb 22, 2008 9:50 am
Hello Dave,
I actually just did that modification to my new Rancilio bottomless from Chris*. Oddly the portafilter did not fit my group near as well as the last one I had. I confirmed it was the portafilter (as I just had the screen/gasket off) by testing with my other portafilters and baskets.
Looking at it I really like the exposed brass look (man I had no idea I was this vain) as it matches the brass ring left from Lino's cut. Still a remarkable portafilter even if I had to file it a bit (thank goodness brass is so soft). Best of all the fit is now perfect (even better than my stock Anita portafilter handle).
*Note to readers the portafilter issue I had was a quirk of the original portafilter's shape and size and in no way was related to the bottomless modification. I highly recommend this portafilter.
Tim
LMWDP #202
TimEggers
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by cannonfodder on Fri Feb 22, 2008 2:03 pm
A triple basket lover I see. The only triple I have uses was on a LM. One of these days I need to order one.
cannonfodder
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by TimEggers on Fri Feb 22, 2008 2:20 pm
cannonfodder wrote:A triple basket lover I see. The only triple I have uses was on a LM. One of these days I need to order one.
I'll admit I've been using my triple baskets a lot here lately and really enjoying the results (I also blame Mr. Rosenthal. :twisted: ) granted I use my convex tamper. I took the photo above with the LM basket that Chris sells with the portafilter to show the modification on the portafilter as purchased.
My favorite (becasue it goes easier on me) is the Synesso triple ridgeless basket from EPNW. The LM is ok but its not as forgiving with me. YMMV.
Tim
LMWDP #202
TimEggers
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by SLC on Sun Feb 24, 2008 11:16 pm
I just modified my LM portafilter as described above. I used a circular motion over the portafilter with the small sander block. It took 3 minutes to go from an almost perfect fit to a perfect fit. It looks great and I finished it off with a very fine grit to get it perfectly smooth.
Thank you for such a great simple idea. The LM is such a wonderful portafilter. It is all I use with Vetrano.
SLC
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by TimEggers on Sun Feb 24, 2008 11:25 pm
SLC wrote:I just modified my LM portafilter as described above. I used a circular motion over the portafilter with the small sander block. It took 3 minutes to go from an almost perfect fit to a perfect fit. It looks great and I finished it off with a very fine grit to get it perfectly smooth.
Your welcome! Its great to hear that it worked as well for you as it has for me and I agree the LM portafilter is a piece of luxury. I love mine!
Tim
LMWDP #202
TimEggers
Link to "How to: La Marzocco OEM Portafilter fit E61 Group (Alternative Modification)"by SLC on Mon Feb 25, 2008 10:54 am
Yes, the "Synesso" 18g basket is the basket I keep going back to. Good combo with the LM PF.
Mark
SLC
www.eccocaffe.com: custom coffee roasted in Northern Italian style
Return to Espresso Machines
