How to adjust La Cimbali Junior doser
Link to "How to adjust La Cimbali Junior doser"by mcpilot on Thu May 22, 2008 9:21 pm
Hello,
I just received my La Cimbali Junior grinder from 1st line. I have it dialed in as far as grind. I was curious about the doser. There is a doser adjustment screw that doesn't seem to turn properly.
Does anyone have any advice as to how to free up the this knob that is inside of the doser so that I can adjust the dose?
mcpilot
Link to "How to adjust La Cimbali Junior doser"by HB on Thu May 22, 2008 9:35 pm
There's no need to bother unless you own a very busy cafe. The dosing mechanism isn't accurate unless you keep the doser half full so the weight of the ground coffee will assure the pie-shaped wedge is full.
www.eccocaffe.com: custom coffee roasted in Northern Italian style
Link to "How to adjust La Cimbali Junior doser"by mcpilot on Thu May 22, 2008 9:46 pm
That makes sense... Thanks...
mcpilot
Link to "How to adjust La Cimbali Junior doser"by Spresso_Bean on Thu May 22, 2008 10:13 pm
If you did ever need to turn that knob, you should press down on it while you turn. I remember reading that back when I first bought my Junior, but the only time I've needed to turn it was to remove the parts for cleaning.
Spresso_Bean
Link to "How to adjust La Cimbali Junior doser"by mcpilot on Fri May 23, 2008 5:21 am
Thats the problem, I am not able to push it down and turn it. IT wont move. When I ry to turn it in the - direction the "star" turns..
mcpilot
Link to "How to adjust La Cimbali Junior doser"by Ducatista on Sat Jun 14, 2008 10:17 am
My CMH just arrived... and I too cannot adjust the "Dose regulating screw".
I realize that it may not matter if but seems odd.
Ducatista
Link to "How to adjust La Cimbali Junior doser"by cafeIKE on Sat Jun 14, 2008 10:31 am
It does not matter unless you intend to fill the doser hopper with about 200g of coffee and use it as intended.
It's quite stiff to adjust.
cafeIKE
Return to Espresso Grinders
