by another_jim on Thu Apr 19, 2007 12:01 pm
The gaskets don't need to be replaced more than once a year, even in 24/7 operation. However, there are several models of shower screen, and some foul with coffee, while others don't. The plain wire shower screens do not foul; the illustrated kind, with the holed metal backup plate, comes in versions that do foul. If you have a fouling kind, you'll need to remove the gasket and clean up the screen every two weeks to a month.
If your gasket is older than about six months, removing it will, in all likelihood, destroy it, since the base tends to bake onto the group surface. Have a spare ready. Otherwise, removing it regularly will prevent this from happening. The best removal gadget is an adjustable collar that fits over the protruding shower screen (there are exotic plumbing tools and occasional jar opening gadgets that will do this). Otherwise, try to find a slightly curved piece of thin steel that can lever out the gasket. There are shower screen models that have a groove, which makes removal easy. The original E61, and some of the Spanish clones, have a notch cut out of the saucer section, which also makes gasket removal a breeze.
