denniskeating wrote:Hi Abe,
Gee, did you come thru Denver on your birthday? Good snow this year.
Oh yes, I did. No snow to be seen in Denver, but Winter Park was packed powder. I carved the slopes for 2 days, half a day in Sulphur Springs, and then Versalab.
My house line pressure is 60 psi. After water filters,I installed a Watts beverage pressure regulator (0-50 lbs) and gage. I figured setting this to 20 lbs psi. Then into my pump, and out to the machine.Will that enable preinfusion at the middle lever position without the pump running?
20 PSI will do pre-infusion in the middle position, though it may take about 9-10 seconds to preinfuse. With such high line pressure you should experiment which pressure works best for you in preinfusion. I'm settled on 50 PSI now, which gives me about 6-7 seconds of preinfusion. But my whole setup was to allow me to change that pressure so I plan to play with that variable.
Also, I thought the relay for actuating the motor was built into the control box, not the main power switch.
Oh yeah, what was your impression of the Versalab Packer?
Dennis
Yes, it is built into the control box. It is activated using the same wires which currently activate the vibe pump. There is a slight difference in the connection, and you should talk to Sean about hooking it up electrically.
The packer is a convenient device and will ensure 30 lbs of level pressure. I'm not sure if it comes in any piston other than 58mm. If it doesn't, you won't be able to use a L/M double basket with it.
