OK, no problem...I made the simple $10 steam pressure gauge which mounts to the steam wand for checking/setting the boiler via pressurestat adjustment. I also just today received the Pump Pressure Check Kit from 1st-Line: http://1st-line.com/parts/other/V512_pump_pressure_check_kit.htm
Simple, right? Just remove the PF spout and affix the Pump Pressure Check Kit. OK, the "kit" part seems t be the inclusion of a nylon ring which fits inside the female threads and an O-ring which fits in the middle of that. No problem...
Well, tonight (minutes ago) I removed the Expobar's PF spout and affixed the Pump Pressure Check Kit. Using the double basket which I mostly use the PF was inserted into the GH as usual and the pump was switched on and WATER flowed out of the GH/PF interface!!! The Expobar's PF is usually used at zero degree position, i.e. sticking straight out the center of the machine. I tightened the PF beyond zero degrees to a couple of degrees to the right (more tight) and water still poured out of the GH. I further tightened the PF into the GH and water still leaked. #&$@! <----- cartoon swearing!!!
This led me to think that the GH gasket might be bad and to confirm that it wasn't this, I used the rubber blank insert which I use for back-flushing into the double basket and the PF was put back into the GH (still with the pressure gauge attached) and again turned the pump ON. This time (with the PF at its normal zero position) the pump built pressure and then the water was shunted to the drip tray via the OPV.
So, do any of you have any idea why my machine might leak with the gauge in use - but won't leak with the same gauge still in the "circuit" but when the blank insert is in use? Please help!!!!
Len
