The temp is controlled with a pressurestat, just like the controls for a HX machine. Since pressure is directly related to temp, the boiler pressure will give you a very close guess as to the boiler temp. You get some cooling as the water passes from the boiler to the grouphead.
Boiler pressure (bar) Water temp (Fahrenheit)
1.0 253
1.1 255
1.2 257
1.3 259
From Dan's HX Love Article
Problem with the Pavoni (and my
Gaggia) is that the GH is directly attached to the boiler. The longer the machine is on, the hotter the GH will get. Eventually it will overheat and have to rest for an hour to cool down.
The 1.2 boiler pressure sounds high for these types of machines. My Gaggia runs about .9 much over 1 bar and you hit the red on the pressure gauge. There is also a pressure relief valve in the boiler cap. If you turn the pressure up you may blow the valve (think of opening the pressure relief valve on a pressure cooker, WOOSH).
Using the Styrofoam cup with a type K TC in it, I get about 192F after a warm up of about 8 min after it hits temp. Guess about 5 degrees drop as the water passes through the portafilter and drops through the 68F air in my office into the cup puts me at about 197-200F, longer warm up=higher temp.
I just got a couple of OmegaLock fittings. I am thinking about mounting one in the bottom of the boiler under the base and put a TC in it so I can watch the temp. no real reason other than I have the fitting.
