I bought my Oscar around March, and I already owned the temp probe setup you see in the picture. I think that one of the things that helped me was to replicate the flowrate and volume through the portafilter when it would be properly tamped with coffee. I took a piece of aluminum foil to restrict the spout of the portafilter while I took measurements during flushes (and my measurements are inside the filter).
One thing I wasn't sure about was how long it takes after doing some flushing/brewing for the boiler and metal to get back to it's highest temps again? 10min? 30min?
I most likely need to run through my process with the temp setup again because it has been three months since I did all that testing, but to answer your immediate question here, it certainly depends on the amount of time the machine has been on. When it is in the first 1/2 hour of use it takes quite a long rebound time when the HX has been exhausted but I would say only around 8 or 10 minutes.
When its been on most of the day it rebounds really quickly, I would say 2 minutes, some things also to consider is with the pourover model and how warm the water is in the tank at the time, compared to refilling it with cold tapwater and operating it.
Just have patience and keep experimenting, you will find a satisfactory method to your flushes.
