How do you know when to change the burrs on a Mazzer Major?
Link to "How do you know when to change the burrs on a Mazzer Major?"by Candace on Fri Aug 04, 2006 1:09 pm
I purchased a Mazzer Major from e-bay and am attempting to clean it by using rice. The motor sounds fine, but it is not grinding the rice very finely. Do you think it needs new burrs?
Candace
Link to "How do you know when to change the burrs on a Mazzer Major?"by JonR10 on Fri Aug 04, 2006 1:27 pm
Welcome to the site Candace!
If the grinder came from ebay, then it likely does need new burrs.
But before you decide, have you looked at them yet?
The collar is used to adjust the grind. You can rotate the collar anti-clockwise to adjust finer.
Do the adjustment while the grinder is running and empty so you can hear if the burrs get close enough to touch.
To check the burrs, remove the top burr assembly.
To do this, rotate the collar clockwise as many turns s necessary until it floats loose.
Remove the top and the upper burr carrier.
Inspect the burrs carefully. You can check to see if the edges are sharp or dulled.
Be careful, very new burrs can shave the skin off your fingertips.
Very old burrs feel softer and smoother.
If needed, you can get Super Jolly replacement burrs
Here: http://www.espressoparts.com/product/MC_19
Or you could also go here: http://stores.ebay.com/Phaelon-Coffee
(I have experience with both - and they are both excellent vendors and fine people)
Cheers,
Jon
JonR10
Link to "How do you know when to change the burrs on a Mazzer Major?"by Candace on Fri Aug 04, 2006 1:38 pm
Reckon you're right! The burrs definitely aren't sharp enough to shave butter, much less my fingertips. (Ouch.) Does the Mazzer Luigi Major have the same parts as the Jolly?
Candace
Link to "How do you know when to change the burrs on a Mazzer Major?"by miKe mcKoffee on Fri Aug 04, 2006 2:24 pm
Candace wrote:Reckon you're right! The burrs definitely aren't sharp enough to shave butter, much less my fingertips. (Ouch.) Does the Mazzer Luigi Major have the same parts as the Jolly?
No, while the Super Jolly burrs are big, yours are Majorly bigger. :lol:
Phaelons eBay store
or
EPNW
FWIW I purchased SJ burrs from Phaelon Coffee no problem. Original Mazzer burrs.
miKe mcKoffee
Link to "How do you know when to change the burrs on a Mazzer Major?"by Candace on Sat Aug 05, 2006 7:47 am
Thanks for the info. We have ordered the fingertip-slicing-burrs from Phaelon. Drink hearty!
Candace
Return to Espresso Grinders
