Ken Fox wrote: What I do understand at this point is that autofill SUCKs, for a bunch of reasons, especially when a machine is used in a low volume setting and when boiler water is not used for drinks.
So I asked myself if I'm entertaining and making a bunch of back to back caps', each cap' steaming started while pulling the shot with steaming typically lasting about 35sec for me w/GP2 running 1bar on the Bric', group flush and group flush wiggle after each shot, quick steam purge 'till heater kicks back on before flash flush & go each shot when would autofill kick in and how would it effect shots and production rate?
Started by initially forcing an autofill via hotwater dump. (I never use Bric's boiler hotwater wand for Americanos or anything else for that matter other than flushing the boiler every few days to bring in fresher water to reduce potential scaling) After forced autofill normal long Bric' cooling flush (~9oz, 16 count beyond end of flash)
Pulled 25sec Thermofilter shots (varying my flash flush & go target temp at random). Right after hitting countdown timer starting steaming, roughly 5sec into shot. Continued steaming 12sec after shot completed. Didn't graph temps just watched the Fluke display.
Autofill kicked in right after finishing steaming for cap' number 5, before group post shot flush/flush & wiggle. As normal on the Bric' boiler pressure dumped ~0.5bar during autofill and took ~20sec to come back up to pressure. Forgot to post shot flush/flush wiggle observing the autofill pressure so did right as came back up to pressure.
Continued cap' series with my normal ~35sec start next shot after post shot flush/flush & wiggle. NOTE: This isn't timed anymore but simply using boiler heating timing. Post shot flush/flush & wiggle kicks on heater. While building the PF the heater will toggle on one more time @ ~25sec (on cycle ~6sec normally). Just before flash flush & wiggle I always purge steam wand to force heater on one more time and start shot flash right after heater toggles off. Why? Primarily so machine always at approx' same state starting a shot. And when I didn't quick purge steam before shot flash I'd sometimes not wait long enough during a series and have no flash.
This 2nd series autofill kicked when purging steam wand before shot #7. (still steaming for caps' each shot) Waited the ~20sec to come back up to pressure then proceeded to flash flush & go. If anything the delay caused longer flash before countdown to temp, no noticeable effect on observed shot temp.
Continued simulated caps'. This 3rd series autofill kicked in right after steaming for cap' #7. And I quit.
That was pulling shots and steaming individually for 18 caps' with autofill kicking in after caps' 5, 6, & 7. How much the autofill actually affected shot profile unknown, but seemed to stay in my usual <1f target shot temp range, both initial high and ending low temps during shot, based on visual observation of Fluke. Total production delay ~1 minute caused by autofill after cap'5 and cap' 11. If I'd continued cap' series beyond 18 another ~30sec production delay before proceeding to #19.
Worthless post as far as hard data goes maybe, but as far as real world usage goes possibly beneficial.
