I was doing my 4th roast in my Hottop 8828B last night.
About 8 minutes into the roast, I started to hear a loud metal on metal scrapping and within 10 seconds the drum locked up and stopped turning
I quickly tried loosing the gold knob a little, maybe a tap or two to see if that would get it going, but nothing... I panicked and pressed the eject button and let the machine go thru most of it's cooling cycle, but the drum NOT turning?
I waited for it to cool, removed the drum and checked for jammed beans and stuff, didn't really find much, but I did see where it was rubbing. It was rubbing on the "Bearing Plate"? I put everything back together, made sure the drum was set in all the way and then just "snugged" the 4 screws holding the bearing plate to the unit, and tried again?
All seemed ok this time? Got a nice roast out of her
1) do you think I hurt the motor from the time the drum was jammed?
2) Now I am paranoid that something is wrong with my "baby", Should I just not worry and forget about it and call it a fluke?
3) Do others ever have Drum Seizing problems?
I am going to try another roast tomorrow and see how that goes?
