Niko wrote:Nice info on the roaster(s), Doug.
Do you think the extra $ is well spent on the newer version of the Hottop? I'm torn between the Gene Cafe and the Hottop, I don't feel like wrangling parts together to build a stir crazy style of roaster (although 1lb batches sounds nice). I'm more after control than batch size and besides saving my precious hearing after using an iRoar2 for quite some time now (it refuses to die).
...and good luck on your eBaying on those cups!
Randy G. wrote:I will have a Gene Cafe in about a week so should be able to offer some comparisons.
Randy G. wrote:iRoast2, for the money, is, IMO, the best bet in a roaster (unless you build one or use a BBQ drum)
Fullsack wrote:The two Hottops I have are responding differently to the same profile. Hitting the marks on the profile that works so well on the earlier model behave differently on the newer Hottop. I had to drop the Variac to 122 to get the above mentioned 220 degrees at 2.5 minutes, 267 at 5:00, 305 at 7:30, 337 at 10:00, 353 at 12:30 and 375 at 15:00 on the newer model.
nicfortin wrote:I tought you didn't need a variac with the newer models?
I've read somewhere (can't find it for now, will edit as soon as I find it) they a have some sort of voltage control integrated in them now, true or not?
Last night I roasted the Organic Mexican that came free from CoffeeBeanCorral. It took about 9:30 minutes to get to first crack (Immediately turned heater down to 50% at this point), 1st crack lasted about 90 seconds. then about a 40 second pause before 2nd crack JUST started and I ejected the beans. So I took the beans just to first pops of second crack, and they seem lighter roast than my first try(Which was my intent, first roast went pretty far into 2nd crack). Seems to me like a nice chocolate brown (City to City+ ? I am guessing)
Fullsack wrote: My first roaster was an iRoast. Thankfully, it self destructed and I got a chance to find out how much better roasts could be, when produced by the HotTop.
Maybe on the fast side going full out heater up to start of 1st then 40% heater for 3:30 to end of roast but the answer will be in the cup. If shots are a bit too aggressive after 4 to 6 days rest, try extending start of 1st to end of roast time a bit. For roasts intended for straight shot espresso I've been slowing the ramp rate beginning 20f before anticipated start of 1st, and target 4:30 start of first to end of roast. I can't give a direct profile input correlation since using CCR HotTop control. Have only been using the CCR HotTop a couple weeks so have a lot more work fine tuning specific profiles for various blends and SOs. Currently using similar end of roast profile for espresso I'd been using profiling with the Rosto. So far I'd say results have varied from equal to better than 5+ years Caffe' Rosto profiled roasts.CyclingCraig wrote:So, is this fast for the Hottop B? What do others profiles look like
CyclingCraig wrote:Second Crack @ 12:08 (Juuuuuusssst start a couple of pops of second)
Eject at 12:30 (Wanted to make sure I was really right at beginings of second crack, that is why I didn't eject RIGHT at above, still learning)
mrgnomer wrote:LOL!![]()
Me too. The Hottop programmable price had me thinking for a while but I'm glad I gave in and got one. I really like the roasts from the Hottop better than the iRoast2, which I got about 300 roasts out of before it started going.
Fullsack wrote:The KN-8828B has an auto mode that allows a modification of the roast parameters. There is a section in the Hottop manual entitled Coffee Varieties and Roast Styles. An excerpt from that section reads, "...when learning to use the Hottop roaster, ...start with 19 minutes on the KN-8828D..."
I would think that the auto mode of the "B" would be the same as the programmed profile in the "D." Try starting with 250 grams, set to the Auto Mode and modify the time parameter to 19:00 minutes. It may be a good generic starting point from which to build something more customized. You can see a copy of the manual online at http://www.hottopusa.com.
