by Sam on Thu May 31, 2007 7:43 am
So, to start out with, the basics: I'm running a Quickmill Alexia at 8.5-9 bars of pressure, fresh beans from Barrington Coffee, a Macap M4 doserless grinder, bottomless PF with a a ridgeless triple basket and one of two tampers (convex and flat).
I moved up to the Alexia a few months ago from a Silvia and Rocky combination. Lately, I've been having realllly frustrating problems with extractions on her. I grind, dose into the PF with a yogurt cup, stir up the grounds, brush to even out the pile, tamp, lock in, and pull the shot. Lately, the puck has had some weird characteristics. There seems to be a shallow crater in the dead center (or, sometimes, just a channeling hole) unless I dose up enough that the only discernible pattern on the puck is the showerscreen.
When I knock out the puck, it comes out in two pieces: a curved mound comes out, and the negative of that is left in the PF. It looks like the sides of what's left in the PF are dark and extracted, while the center is lighter and looks underextracted and dry-ish. What would cause such an uneven extraction through the puck's center? I've used both a flat and curved tamper, varied tamping pressure, etc.
The shots have also started to blond early and don't have a really dark, rich crema that I'm able to get at the shop down the street (pulling the same beans on a Cyncra... which, obviously, is a tad fancier). Help... please.
