Hey all, today I started following RegulatorJohnson's descale method as outlined here:
http://www.expobarownersgroup.com...ew&id=13&Itemid=32
I moved the switch on the bottom of the water tank holding area so that it would fill when up rather than when pushed down as shown in those instructions. At first everything was going fine. I emptied the boiler through the hot water tap and then turned the machine on. It began to refill. I turned it back off for a second to adjust my water intake tube that is stuck into a gallon water jug right now. Then I turned it back on and it would not continue to refill the boiler. I checked the connection of the wires on the weight switch where the normal water tank goes. They look fine. The pump still works because it will pump water out the brew head and I can see the water pumping out of the tank into the boiler as well while the pump is turned on. It just won't pump to fill the boiler.
Any ideas?
I posted this at expobarownersgroup too but then it occurred to me that the traffic there is very slow and I might not get an answer for a while. I'd like to get this solved today if possible.
brad
