I need help diagnosing an intermittent control problem with my auto HX machine. Perhaps someone can review this and suggest ways to narrow the potential causes?
The machine is a 2004 Wega Lyra/mininova. The main control board on this machine is a Gicar, and the brew flow control is a programmable flow Giemme unit.
Emergence of ProblemThe machine operated flawlessly until a few weeks ago, when the troubles began.
I first noticed a problem when activating the brew switch began causing the brew solenoid to click, but would not start the pump or open the brew solenoid.
I replaced the brew solenoid and valve with new parts. When I first restarted the machine after this replacement, it malfunctioned for the first 10 shots or so, then began working normally. This eliminated the problem for a few weeks, and I thought everything was fine. But now the problem is coming back intermittently.
I'll describe the behaviour and perhaps someone can suggest a way to narrow the list of possibilities.
Hot Water Control SystemThis machine has a dedicated switch and solenoid to activate the hot water tap.
No matter what has happened with the brew control circuits, the hot water control continues to operate normally. Turning it on engages the pump and produces hot water with no interruptions, regardless of what is happening with the brew control. I think this eliminates the pump and pump circuit problems from the list of possible causes, and narrows the potential problems to the brew control system.
Brew Control SystemSometimes, the brew control system works properly.
Other times, turning on the brew switch starts the pump for several seconds, but it shuts off spontaneously part way through the shot. When this happens, it has been possible to restart it immediately to finish the shot.
Still other times, turning on the brew switch has resulted in a click in the Gicar control unit and a simultaneous clunk in the brew solenoid. But it spontaneously shuts off within a fraction of a second. When this happens, the Gicar controller sometimes begins clicking continuously, stopping only when the main power to the machine is turned off. This seems to be identical to the problem I experienced before replacing the brew solenoid and valve.
Automatic Brew Flow ControllerThis machine is an auto with programmable flow control managed by a Giemme flow control unit.
Disconnecting power to the Giemme flow control unit does not affect the errant behaviour of the machine. Brew Control TouchpadThe brew switch and brew programming control is a 4 position touchpad connected to the Gicar control box by a ribbon connector. See parts 11 and 13 on this diagram:
http://www.espressoparts.com/cate...electrical_system/I don't know how to diagnose a problem with the touchpad. Is it likely that this is the problem?
I can order a new Gicar control unit (
it's $483!!) but I don't want to do so until I can confirm it is the problem. I certainly don't want to order and install a new Gicar control unit only to discover that it isn't the problem, and then I can't return it because it's used.
Any suggestions?
