The Wega uses the "E60.5" group, which does not have a lever/cam and doesn't preinfuse. Ken's and Jim's posts suggested that preinfusion may be helpful with a rotary pump, and I thought it was worthy of a small experiment.
Ken generously emailed his description of the timed relay he's using as well as wiring instructions, which he got from Andy S. Andy's instructions to Ken read:
"Neutral wire is hooked to terminal A (on timed relay).
Hot side voltage that normally goes to pump goes instead to both B terminals (on timed relay).
After time delay period, terminal C (on timed relay) is energized. C is hooked to pump motor hot side. "
My difficulty is figuring out which is the hot, which is neutral.
The pump motor on my Wega has 5 wires going into it - Blue1, Blue2, Brown1, Brown2 and green/yellow. (Green/yellow appears to be ground - the ground connections to the Wega frame are all Green/yellow.)
Blue2 and Brown2 connect to the motor start capacitor, so they're out of the picture.
That means the relevant "hot" and "neutral" are Blue1 and Brown1 - but which is which?
The only hint I have is that Blue1 connects to terminal F5 labeled "POMPA" on the GICAR controller (see photo below).
On the other side of the GICAR, there's a diagram showing "+ OUT -", and there's one blue wire connected to the + side.
So I'm guessing blue is hot and the brown is neutral?
Any hints, including suggestions for how to test whether that's correct?
Thanks,
Rick
