Overview
Here's a photo of my espresso setup as I'm getting ready to test the tampers I've selected for review. I have a Solis SL70 which really got a workout for a couple of days (reminded me of "The Little Engine That Could")! In addition, you see my MACAP MKXR conical grinder.
I use a naked PF along with an aftermarket 53mm double basket. Regarding tamping, I tamp to about 40+lb and then follow that with a lighter NSEW tamp and finish with a polish tamp. My standard dose is about 14.8 - 14.9 grams of coffee. For this review I weighed all the baskets prior to tamping to ensure I was consistent.
Selection
My selection process required that I use something that came with 53mm pistons. Luckily, several of the EPNW tampers which were still "un-reviewed" came with one. Also since my standard home tamper is a Reg Barber Short Bublinga I was also able to try both of the Reg Barber tampers by utilizing my 53mm piston.
So, for my "fifteen minutes of fame" tamper review I selected the Reg Barber Radical Pro, EPNW Pro, and EPNW Lava. Here they are pictured along with my home tamper which is a Reg Barber Short Bublinga.
My standard piston is flat and the included 53mm for the EPNW tampers was flat as well so my review comments are based on that. (Ignore the fact that in the photo the tampers don't all have the same size or type pistons on them.)
Appearance - I happen to have liked the simple appearance and to my eyes the contemporary look of the Radical Pro. I definitely have a design bent probably due to some early art training and having designed a lot of web applications, so simple clean lines appeal to me. I was also drawn by the Radical Pro's unique look compared to that of the other tampers.
The grain in the wood handle is beautiful with a very nice finish which is smooth (i.e., no raised grain here!), and the fit to the piston is perfect. However, the finish did appear to be wearing off slightly. This surprised me somewhat because even though I'm sure this has gotten a fair amount of use while on the "road show" my everyday Reg Barber tamper in comparison still looks almost brand new and I've had it awhile since it's the only (real) one I've ever owned.
Feel - I found the feel to be very comfortable and the grip somewhat second nature. As others have mentioned it's more like gripping a golf club. When I tamp I like to have the pressure distributed between that applied by my fingers and that of top of the tamper handle. When using the Radical Pro since the handle is tall the pressure of course is placed near the wrist (versus the soft part of the palm) which I found acceptable and comfortable. I didn't have any issue with most of the weight being in the piston, but because the handle is long it obviously isn't one you can "cradle/palm" in your hand when tamping.
Usage - Alas, I secretly was hoping this would be my favorite, but in practice I never could become "in tune" with it. I liked the fact that it forces you to apply pressure straight down and this should result in a very even tamp. And since I'm fairly tall (6') and use a naked PF (so the PF is lower to the counter) I should have been a perfect candidate for it. While I could get level tamps while using this tamper it seemed to take more concentration and I didn't feel as confident about it. I think in my case since you are forced to be more "above" the tamper when you look down to check your tamp I had trouble looking on the right side of the basket to ensure the tamper was level. I think if you are someone who rests their fingers on the basket to ensure a level tamp then this probably would work fine. I can definitely say I didn't have any "bad" shots while using this, but it definitely took more effort than any of the rest.
EPNW Pro
Appearance - Once again a very contemporary look which I liked. Being all metal gives it a modern sculpture like and functional appearance. The satiny finish is nice and seems to have held up very well given all of the use it's probably has gotten during the road show. The black accents on the top of the handle and base of the handle nicely provide some contrast to the rest of the metal.
Feel - It seemed a little heavy for me, but not by much. Also the top of the handle was a little small and made grasping it a bit more difficult. But the beveled piston and the slightly rounded area where the handle and piston meet are very comfortable and provide a nice area for your fingers when tamping. This certainly would be a good one if you like to "cradle/palm" the tamper.
Usage - While I liked using this tamper it wasn't my favorite mostly because the top of the handle was a little small for me (if it had a slightly larger handle top like the Bumper it probably would have been perfect). Even though this wasn't my favorite I wouldn't have any problem with using this as my everyday tamper. It seemed pretty easy to ensure the tamper was level and I didn't any problem pulling good shots while using it. Also because it's all metal you don't have to worry about it as much as say the La Forza.
EPNW Lava Deluxe
Appearance - While I don't think this tamper looks bad I will admit I definitely didn't like the looks of it from the beginning. Only the EPNW Import Lava was lower on my initial impression list. While the green handle and top accent on the handle just happened to have gone well with the green flexible cutting board I place under my grinder when making espresso to allow for better cleanup I thought the green looked a little "weird". Also the top of the handle is shiny which not only gives it a slightly "cheap" appearance but also ends up showing nicks and marks easily. I think if it was more satin or brushed in appearance the overall appearance of the tamper would be improved and any use wouldn't be as obvious.
Feel - For me the weight was near perfect. It has some heft but still light enough where you feel like you are controlling the tamper versus the tamper controlling you. While I think the top of the handle could have been just a tad bigger for my hand it still felt comfortable and the length of the handle is near perfect. And like the EPNW Pro the beveled piston and the slightly rounded area where the handle and piston meet are very comfortable and provide a nice area for your fingers when tamping.
Usage - As much as I initially didn't like the looks of this tamper and think it looks a little "cheap" it eventually won me over! By the end of the road show whenever I just wanted to pull a shot (versus test a tamper for review purposes) it was the one I reached for. It was very easy to get level tamps and the weight was near perfect for me. Because it isn't too heavy or the handle too tall it's an easy one if you like to "cradle" the tamper and use more "finesse".
At first I was convinced I was getting better shots from the EPNW Pro and the EPNW Lava (versus the Radical Pro and my everyday Reg Barber tamper). While I'd have to do a lot more shots to really verify that was true, I think that any difference was probably more related to the piston size than the handles. It turns out that the EPNW 53mm piston is slightly smaller in diameter than my Reg Barber 53mm and it also has a slightly lower height. So it may be because I like to do a NSEW tamp that the smaller piston helped make that easier. And because the EPNW 53mm piston has a slightly smaller height the piston was actually level with the top of my basket which probably made it easier for me to determine that I was providing a level tamp.
Conclusion
At first I was drawn to the tampers which had "heft" and size. These included the tampers like the Pullman, Compressore, and the Clicker for instance. When you picked those up you knew they were serious and in many cases beautiful as well. But in practice for me if the tamper was heavy I felt like they were controlling what I was doing versus allowing me to control them. The lighter ones were easier to "finesse" and feel what you were doing.
For me the tampers which were the easiest to use were ones which had handles which fit my palm and were short enough so that they were easy to "cradle/palm", as well as apply pressure using both my fingers and palm. Lastly, the tampers which had beveled pistons and rounded areas where the piston and handle meet also were the most comfortable for me.
Lastly, it quickly became apparent that my everyday tamper didn't fit me very well (it was a present from my wife so I didn't select it!). As you can see in the photo the handle is too short for me. Slightly taller it would just fit in the area at the thumb joint. For comparison you can see how the Espressocraft fits nicely in my palm. And even for the Radical Pro the handle actually fit nicely at the top of my hand. So using either of those it was easy to apply pressure using both the palm and fingers.
I've always had some problems in getting level tamps using my everyday Reg Barber. So it was easy for me to determine that because it doesn't fit well I sometimes apply more pressure on the left side of the PF. And when you factor in that being tall I have a tendency to apply more pressure away from me anyway I will definitely be in the market for a new tamper soon (which will be an EPNW Lava Deluxe)!
Overall Favorites
So to close out here are my favorites selected from the entire collection.
EPNW Lava Deluxe
Espressocraft
Bumper
I thoroughly enjoyed the opportunity to try all of these tampers! Special thanks to EspressoParts! I think I'll be ordering my EPNW Lava Deluxe (probably black) soon!
