peacecup wrote:Now that looks like the kind of collection, along with your different lever machines, that could really provide some insight into how these grinders work. We'll be looking forward to hearing about some of the differences - one thing I have heard is that the adjustment wheel on the top axle tends to change adjustment during grinding - have you noticed this on any?
I see you have one of the Dienes carved box mills - is that the one with the bakelite drawer that you recently bid on - mine has a plastic drawer, all of which seem to warp after time and don't fit well.
Sometime it may be worth taking side-by-side photos of some of the burrs if there are big differences.
Thanks for posting!
PC
The axle wheel does turn on my grinders during grinding. I turn it back a little after each rotation.
That is the Dienes mill I recently bid on and yep, it has the same drawer as yours. I haven't used it yet. How does your Dienes perform compared to your other grinders?
The side-by-side burr photos are a good idea. Maybe other leverheads will notice differences I missed.
ogatasan wrote:Doug, i am impressed by your collection.
as i am about to move country for the 5th time in 5 years i wonder if i should invest in a decent handgrinder rather than a Mazzer Mini, Super Jolly or a Maccap...
- can you or other members say something about the quality and usability of the zass mocca grinder (topleft) ?
- would you have a recommendation for a specific handgrinder (to go with the Europiccola)?
- can they keep up with a decent electric grinder in your experience? (yes, I have read the titan and other reviews)
Thanks so much,
That brass grinder is my least favorite. It is more cumbersome to use and even though it is new, it doesn't produce results that are on a par with my other hand grinders.
Grinding for a lever machine requires a finer grind than other machines. A good hand grinder is up to the task. Hand grinders produce more fluff that arguably, makes a better tasting shot.
Buy your hand grinder on eBay from a German seller and be sure it says Made in
Western Germany on the bottom. My best grinder, the Zassenhaus 153, has a stainless steel shaft rather than a black one and is brass on the bottom instead of black. See if you can get the seller to take a picture of the bottom of the shaft by removing the drawer.
http://www.home-barista.com/forum...senhaus-t3751.html
