Hi,
I have a new Zass open-hopper model (161 I believe), and after reading through this thread (whew!) I decided to try Peacecup's greeting card doser. (First I'd tried a folded paper plate as a funnel, but the grounds still wanted to either stick to the plate or go rushing down into the PF all at once, depending on the angle.) Anyway, I didn't have a greeting card handy, so I cut up a heavy-duty manila folder. Here's the problem: after a few seconds of tapping with this doser, nothing more comes out. The coffee seems to be packing itself against the manila and staying there instead of falling down into the triangular "dosing chamber". Would glossier paper (like from, oh, I dunno, say, a greeting card?
) fix this? I'm also wondering if the drawer on my Zass holds less than the one in Peacecup's video... when I first started out and was fiddling with dose and grind, I was easily overfilling the drawer.
Over the weekend, I dug through our assortment of paper plates and tried the funnel thing again, then decided to use a chopstick to nudge the grinds down the "chute". Ended up using a plastic plate, and found that whacking the sides of the plate with the chopstick provided just enough agitation to move the grinds along bit by bit. (It also makes a lot of non-electric noise, which is kinda fun for me though I can't speak for the other inhabitants of the house.)
If only I'd thought of using one of those plastic plates as a greeting card doser substitute before I ran out.
Slight change of subject: Psyd, the tag on my Zass says Kaffeemuhle, FWIW.
