caeffe wrote:On the left is a PeDe Moka, and next to it is an Armin Trosser.
The Mazzer Major is not quite manual though and was a previous purchase long ago....
I haven't used the hand grinders yet - I'd like to clean them up first. How does one disassemble these beauts for cleaning of the burrs? Once disassembled, how do you establish an espresso grind for them? Do you adjust till the burrs touch then back off say one or two revolutions?
For now, I'm still semi-auto with the europiccola as the Major is doing the grinding .....
The Trosser is my daily driver. Wrench off the top bolt and unscrew the handle. You might have to hold the shaft to get the handle off.
Carefully loosen the four screws at the top corners and pull the top off, after noting which side goes where. Then study the bottom side until you are confident you can reassemble it in the same way. Its not hard, but be careful.
OR, use Minute Rice to clean the burrs until you are happy with it. Then get ready to use some beans to get the grinder set for espresso. The burrs on my Trosser rub against each other (in a good way) but turn easily and make a very nice grind, perfect for the Factory. You may have to tweak the bracket underneath to get the burrs aligned. If the adjuster doesn't turn, it will need some persuasion. This shot is of a Trosser no longer in use:
I will be curious how the hand grinders do vs the Mazzer Major. I would think for the money that the Mazzer has to be more consistent in grind. But for the money the Trosser is a no-brainer for me.
But FIVE Trossers?
